Speakers
Elsinore kit parts drivers & built crossovers $3000 each.
101 db @1w1m Peavey SP2-XT about $200. I paid $600 for a pair but that was 10 years ago. Peaveys are smaller, too.
98 db @1w1m Peavey SP2-2004 I bought in May were $400 the pair. Huge, but so smooth. I listen @ 1/8 to 70 W, nothing like the 500 W they are rated for. Look at distortion chart @ 1% power - 2nd harmonic 20 db down 80 hz to 12 khz. Never seen that chart on another speaker.
rock12, Are you looking for good recommendations of new/used finished speakers you can purchase? DIY designs you can build?
Room size / shape?. Budget?. woodshop?.
DIY BASIC...good quality:
---- 95db/watt 2-way with the 12" Faital 12PR320 woofer ( 2cuft ported -F3~50Hz ). Crossover at 1200Hz to Faital HF108 1-inch compression driver -F3~19kHz on LTH102 horn(on-top or inside the cabinet)
Perhaps the Asathor is something for you:
Asathor - a JBL 4367 Clone
There are pictures and measurements in post # 7. Blueprint in post # 34. X-Over with impedance correction for tube amps is in post # 191.
All information is also available here, but only in German:
Asathor - Preiswerte Mannerbox - Der-Akustische-Untergrund
The Asathor delivers around 93dB / 1W and goes down to around 45 Hz (f3). For two speakers you have to pay ~500 € plus wood and finish.
