New PCB for MM RIAA using 9AJ based 9 pin tubes.
So I designed a circuit board for MM and high output MC carts.
It uses active loading, and 16 triodes.
9AJ base. I designed it for 6N1P 1st and 2nd position, 6N2P for 3rd, and 6N1P for 4th. You can sub 6DJ8 for the 6N1P in this design, too. Any tubes that fit and have a 9AJ pinout will work if you make the appropriate resistor changes.
Here's an example I built as a test. The board requires 12V for heat (DC preferred, no special accommodation was made for AC so some hum might ensue) and 280V or so for B+.
I'm selling the blank boards for 25$ plus post. I can also include parts if you need them.
I'm offering this complete board including new tubes for 150$ shipped to you. All the film capacitors are metallized polypropylene, and the sockets are ceramic.
If you're interested in any of this, send a message!
Have an awesome day!
Any chance to publish the actual RIAA characteristic? 🙂
If you use crap parts you would have crap results, of course.
Using good commercial parts of values as noted, the accuracy is OK. Better than OK. Very-very good. Within 0.026dB of the prescribed time constants.
I have assumed that a cathode follower is 500 Ohms out, a grid is infinite, and the tubes are flat over the audio band (no 300Meg gridstopper).
