Power tube amp for guitar
Look .. I make the same mod on my 1974x clone and work pretty fine and is exactly the same way of Marshall 1974x with Phoenix … so I think to put on the first gain stage the 12AY7( maybe 12AX7 because now I have the master volume so I don’t care about gain ) sure the master volume must added ..
And here are both of Phoenix mod master volume and the 1974x 39676720-9CBD-41B9-9F26-24DB29F3C13B.png
Here is page 58 from the manual you linked to in your post #47. See steps 12, 13 and 14. Step 12 says to connect terminal 2 of the pot to turret T38 on the turret board.
But on the diagram on page 59 terminal 2 of the pot is connected to turret T46 on the turret board.
I think that the diagram in the manual is wrong.
I advise you to connect the pot in your amplifier like in the attached schematic.
Addition: Maybe it's wise to add a 1M resistor from each wiper to ground. This prevents the control grids of the EL84's floating in case the pot goes dusty/bad.
Yes you’re correct the page 58 is wrong but the diagram on the page 59 is correct . This is I make it and work fine . Without buzz or unwanted noises … 3585DB83-21DB-4BF0-A43A-05CD40F6A344.png you send me this diagram , that’s I’m thinking to make and this is the same with 1974x .. that is work ..
I have one last question , just get out of my head .. the main transformer have 2 currents . The circuit voltage and the filaments voltage .. the circuit voltage are 2 x 220vac ( or something else ) and the tap on the centre … and the filament wires are 1x 6.3vac + 1x 0vac or 6.3 vac + 6.3 vac ????
