DIY Sony VFET lottery discussion
Question to Gianluca
- The Chassis set of screws /some with nuts are of different sizes. where to use shorter screws compared to larger ones is not shown in the picture that came with chassis. Is there a guide for assembling the chassis?
Since the chassis is based on a Dissipante 4U model, I suggest you to have to a look at this guide which may help Illustrated guide to the 4U deluxe Chassis
I believe in Pa (as always, he's my Pa) ....... but I don't believe he's going to present something revolutionary with big Tokins; few reasons:
- target group - interests and overall level of capability
-he said ultra-precise matching doesn't matter
-he already posted more than enough revolutionary** thingies and even more if not revolutionary then damn good engineering tricks
**read as Blasphemy; at least they are that, same as Zen amp was Blasphemy in time of publishing ; see where that lead Greedy Boyz, in time
:rofl:
moral of my rant is - you have THFs - see several amps made with Tokins, choose what you like most - build
if Pa come later with something more to your liking, pull Tokins for that
:rofl:
Which of your designs (or someone else's design) offers the best sound quality with the THF-51S?
I've been a bit reluctant to try one of your builds. They always seem to assume a level of knowledge I don't possess or perhaps just a bit of confusion on my part about how you express yourself.
Lol -- Zen Mod is awesome, that's all you gotta know. 🙂
If you have high sensitivity speakers, probably SissySIT. If you need more wattage for your use case, check out Singing Bush or Lazy Singing Bush.
From my [limited] research so far, it sounds like these amps are blowing people away with their sound quality.
even if I'm in permanent mode of blatant self-promotion :rofl: , this is really homework for you ....... to rummage through threads, see what is interesting , then ask what you want in appropriate threads
my amps are, in fact, simple
just few parts actually singing, while everything else having auxiliary role
