AZ OLED setup kits for Soekris dam1021/1121 control
Just my Audiozen and Sokris dam1021 build into a case. I expand the analog audio output with a switch and a relay. So I have the possibility to switch the output with or without buffer easy from the outside, without to open the case.
Kurt Blum
DIY AUDIOPHILE TUBE ELECTRONIC | "es bizeli zuesatzliche infos fuer de audio rohre chlutteri" Swiss-German translation ;-)
hello everybody,
please help me out, I am quite new to the diy-sector, and happily (and successfully 😉 built a 1021 dam dac, based on the audiozen board.
I want to take it a step up and use two external psus, one for the dac, one for the usb module. I just dont want to damage anything, thats why I am asking:
for the dac: I have to disconnect j7 and feed it via these pins with the external power (two sals ultrabibs), right?
but: where do i have to power the usb-module?
thanks, and all the best!
