Another version of the Doug Self Preamp
Start 2 years ago after i bought, finish and test the Carl_Huff kit.
New design and new layout with the option to try different potentiometers and input caps.
The PSU is in the same PCB with LM317 & LM337. Adjunction also of a Phono Preamp.
Thank you to Gianluca from Modushop for the front and rear panel, was not easy to center the printing with the holes,
they use 2 different machines and between tolerances and everything they could be slightly off center, but they are prefect.
And of course thank you to Doug Self for this wonderful Preamp.
Reactions: asuslover
