Start 2 years ago after i bought, finish and test the Carl_Huff kit.
New design and new layout with the option to try different potentiometers and input caps.
The PSU is in the same PCB with LM317 & LM337. Adjunction also of a Phono Preamp.
Thank you to Gianluca from Modushop for the front and rear panel, was not easy to center the printing with the holes,
they use 2 different machines and between tolerances and everything they could be slightly off center, but they are prefect.
And of course thank you to Doug Self for this wonderful Preamp.
Very nice!
Although you have posted thousands upon thousands of words in pictures, would you provide a narrative of your build? The parts you chose could be a thread on their own - impressive!
Thanks, yes i will later with my english words from a French manVery nice!
A stunning build! Congratulations.
Do you propose to make these boards available?
Graeme
Thanks Greame, Actually i have couple of spare board (4) from this build, I have the Doug Self agreement to publish this thread. But if they are interest for a GB, i have to check with him
- Analog Line Level
- Another version of the Doug Self Preamp
