Joined 2009
What I wanna know is since the ocean is exerting the same counteractive force as the Earth against the gravitational pull of the Moon and Sun, why should there even be a rising tide? Makes no sense whatsoever! 😡
Does my weight change with the tide? Can I jump higher with a rising tide? Would my squirt gun shoot higher?? Sheesh.
Yes, your weight varies due to the movement of the heavenly bodies. We’ll leave your squirt gun out of it.
I thought it was a yes or no question.
Nuance is lost on you. Not that the difference between the two is particularly nuanced.
I think we know more about gravity than you realize. Gravity is used in every single civil structure design, as well as in a flight engineer's pre-flight calculations. Gravity is what makes the solar system work. Gravity is what causes the tides.
All of this stuff can be precisely calculated, with virtually 100% reliability.
It's that false equivalence fallacy again.
You mean gravity is accounted for. Use of it would mean manipulating it as in wielding fire to different temperature to cut through or join metal for construction. Unless you are trying to say that we can wield gravity to different levels.Gravity is used in every single civil structure design,
@Fast EddieD A bit like EM Theory I’d say. The precision with which particles in LHC can be accelerated and collided from opposite directions is akin to firing golf balls from NYC and London so they collide over the mid-Atlantic. And yet, Prof Daniel Fleisch describes the underlying mechanism for EMR as ‘deeply philosophical’. We don’t know, but can describe the behavior of EM radiation and it’s effects on particles with exquisite precision. Just like gravity (although there are numerous explanations, none universally agreed upon).
Francis Bacon said, "Nature, to be commanded, must be obeyed."
He didn't say it had to be fully understood, and that applies to any intelligent life (and more broadly, to all life).
I personally would say "full understanding" isn't even a goal of science. But the philosophers can keep trying.
How would you describe the operation of a mass balance sans gravity?
How about narrowing things down to more specifics (i.e. wielding fire to different temperature to cut through or join metal for construction)?mass balance sans gravity?
Every orbiting satellite wields gravity to maintain its trajectory.
It's not really something you can gather and keep in a toolbox.
It wields its propellant to move to or remain at certain location. If it can wield gravity, it won't need the propellant.Every orbiting satellite wields gravity to maintain its trajectory.
How about gravity assist acceleration of satellites? These wield the curvature of space-time due to gravity to facilitate kinetic acceleration.
Examples: Voyager I, Voyager II and the Parker probe - the first two to gain energy, the last to remove it.
Yes. Without knowing what it actually is. Which is my point. What’s your point? Are you trying to equate an understanding of the inner workings of something with understanding its interaction with the physical world? These two things are not the same. I can lie outside on a sunny day and get a tan with 100% predictability without having any understanding of how the sun works. Why do you repeatedly use this false equivalent? It’s not the same thing.
When I tan I wield the the sun to darken my skin.
Inertia keeps it moving. Even geosynchronous satellites.It wields its propellant to move to or remain at certain location. If it can wield gravity, it won't need the propellant.
You knew what I meant when you posted and deleted "Nope...".
Answer my post #1394.
That would be wielding of inertia with given gravity, similar to something down to earth.How about gravity assist acceleration of satellites? These wield the curvature of space-time due to gravity to facilitate kinetic acceleration.
Taking advantage of the known properties of a phenomenon is not the same as understanding its inner workings. The “we understand gravity” people seem to disagree with this statement, and this makes no sense.
- Member Areas
- The Lounge
- UFO's- Please help me process
