(actually Lab Gruppen was bought by the parent company of Behringer and they released this amplifier as an entry level item)
Vale Lab Gruppen.
"MUSIC Group (the parent company of Midas, Klark Teknik, Turbosound, Behringer and Bugera) has announced that it has acquired TC Group (parent company of Tannoy, Lab Gruppen, Lake, TC Electronics, TC Helicon and TC Applied Technologies)"
This happened in 2015. Oh well.
Mixed amp with different topology or class is very common in Pro Audio. But in Pro you use DLMS to make all coherent.
For home I suggest you install processor at least there is delay option there as per my understanding you will install subwoofer. Placing the subwoofer also need at center line between LR speaker, then need phase alignment with LR speaker
For the record, that was regarding the single subwoofer setup.
If you make some diy floorstanders most proper and thought-through designs have no need for subwoofers.
Even basic 2-2,5way with double 6,5" in a sealed enclosure can wipe the floor with similarly priced off the shelf speakers.
DSP is very good help, but not an absolute must, depends on the setup.
I'm using four subs (one in each corner of the room) and 12" midbass in a small room with DSP 😀 But this Thread is about amps. If you are interested I can open a new one with some measurements and details about my project.
Not meaning to highjack the thread but corner placement for subs is far from a good ideas and leads to suboptimal room mode distribution (uneven bass).I'm using four subs (one in each corner of the room) ...
Drumberg, I for one would be interested.. seeing as I feel I've probably learned more about it in theory than from actual projects using this method.
Drumberg, good threads always have a few graphs and pictures *hint* *hint*. 🙂
Allen, as long as there is more than one, run sweeps over a larger area to find the important bits that stand out over several measurement spots, measure and adjust each sub separately.
Are there any other kinds? 😀
suboptimal room
I know people say it's a bad idea to put speakers and subs in the corner. But every room and setup is different so testing is always necessary. It works for me so far. The FR is great but maybe there is improvement in the time domain possible.
I will open a new thread for my project and I'll post the link here. Not sure when this will happen. Still need to extract the right measurements and prepare a sketch.
Yes, every room is different. And small rooms are sometimes a bit easier than large-ish rooms unless you get over a certain limit.
- Class D
- Mixing Class D with AB?
