Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
Official Court Jester
Joined 2003
Few years ago, we had enormous fun in funny named thread : F4 Beast Builders
Well, you can call it Group of Hysteric Housewives Brainstorming :rofl: 😛
Result of that was that I had myriad of back of napkin sketches, and after these I started simulating ...... and simulating ... and simulating
After myriad of sims ( out of sheer enthusiasm I even made pcb files for some of iterations), I finally had made nice smallish channel pcbs, containing OS having different-ish approach to biasing than Papa's original XA25, while FE was in principle same as Papa's, but with few beautiful quirks, of which I was damn proud (yup, Mighty ZM reinventing Da Wheel, time and time again)
And they were sitting, populated, on my shelf ........ always being pushed to bottom of list; I knew they would work, but somehow I wasn't content with overall picture
Now, recently - besides revising biasing mechanismus for SissySIT ( resulting in R.3) and few other amps, I also made FE called Plethora of Pinjatas ( or just Plethora, short) and found interesting to combine it in sitting Babelfish XA25 project
Plethora Fe having both SE and Bal inputs as matter of choice, called to adding another "2" in name , so result is Babelfish XA252
Plan is also to have iteration of DEF OS ( real SIT, no emulation in form of Schaded Mosfet), thus addition of "SIT" in name, so Babelfish XA252 / SIT
Find enclosed cumulative schematic, and will do edits of this post, if and when needed
OK1-OK2-TH1 .......... 10A limiting circuit, Savior of Our Souls, blatantly stolen from Pa 😛
amp is phase correct , Papa's fave gigglywiggly graphs sez that 2nd is negative phase
all measurements made with SE input, neg leg input grounded
edit on 18.07.2021.
Babelfish XA252 SIT - post #64 Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
Babelfish XA252 SET - post #119 Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
edit on 18.12.2022.
separate schmtc for Full Mos, SET, SIT iterations, post #624
ignore notes on schematics about "do not mount" - just follow schematics
read all down for separate schmtcs, Extra-carefully made set of files, for each of 3 amp iterations
short setting procedure:
P1 is for DC Offset, P2 is for Iq
do not forget to have grounded neg input , presuming you're using it SE input, but also ground positive input, temporary
no load at output
P1 irrelevant for start how it's set
P2 set to max value - check with probes across unpopulated Rt, that one being in parallel with P2; that way pre-set is min Iq
I don't care for left-right orientation of trimpots - never taking care about that when making pcbs - too much times in my service work I
expected some logic with trimpots orientation, just to be confused and from then on, I'm just using DMM as guide
leave JP1 open for start
advisable to put temporary fuses in rails - say 2A
if you have variac, use it
of course, regular praxis - one DVM across rail sense resistor group ( + or -, irrelevant) - Iq observer
second DVM at output, offset observer
power up, have an eye on Iq observer;
DC offset for start - good even if few volts, but normal to expect few dozen of mV
now, fiddle with P2, slowly, to get half of intended Iq
observe DC offset is it still OK
give it time to develop some heat in heatsinks, then increase Iq to 75%
if everything is stable, close JP1 ( alive, no need to power off for that), try to minimize DC offset as much you can
if that is done, open JP1 ( alive, no need to power off for that), wait for some time to get closer to temp equilibrium, increase Iq to
final desired value
that's it
try few lazy powering off - powering On sequences, observe behaviour
if everything is OK, power off, remove temporary fuses, wire rails properly
proceed/repeat procedure with second channel
edit on 22.12.2023.
set of files for last iteration, Post #1386 - consider it as hair-splitting changes, gilding da lilly, whatever; ZM playing in Sandbox...
read down.....
Edit on 07. Jan. 2024.
Extra-carefully made set of files, for each of 3 amp iterations, post #1462
https://www.diyaudio.com/community/...2-sit-babelfish-xa252-set.373443/post-7560120
Edit on 03.02.2025.
Important revision of protection circuit:
read post #2573, https://www.diyaudio.com/community/...2-sit-babelfish-xa252-set.373443/post-7919078
Now, for clarity sake, there is edited schm, parts needed for SIT iteration omitted
few more funny pics, too
Reactions: Russellc
I did planned before to make it, but finally made T-Bed 2 , as proper cradle for prototyping this
from one of pics, you can clearly see that ZM is Chicken , executing first power up and settings with IRFP240/9140 and 2A fuses in rails...... did it with smallish Iq, and later - when I was happy camper, changed to Biguns
Reactions: Russellc
Graphs , 8R load, BFR=22R
FE is made as more or less basic LTP thingy; though, I did wanted to have possibility of altering THD level by changing OLG in simple and predictable way - which I made in also basic way - tearing LTP halves ( each halve having own CCS) and introducing common degeneration resistor ( practically changing length of effective Tail of LTP) , which I then named as Beauty Factor Resistor, short BFR
as you will see, changing value of that resistor is chhanging OLG, thus changing amount of overall NFB, and as result we have lesser or higher THD level
Luckily, Spectra is not changing, and that was a goal :clown:
now - set of measurements with highest possible OLG - BFR s 22R
Rails are 30Vdc ( amp projected to work with rails of 30-35Vdc with no changes)
Iq 1A7
DC offset and Iq practically not changing in temperature domain
While varying mains voltage (nominal 230Vac) between 200Vac and 255Vac - DC offset is changing some 20mV, while Iq is practically not changing
Good enough for me :devily:
Load for these graphs is 8R; each graph is having title captured, so you can see what/how much
Graphs , 8R load, BFR=22R, continued
too many pics for one post, so continued
due to 30Vdc rails, clipping smidge above 40W
with 35Vdc rails, clip near 55W
who needs that ?
Graphs , 4R load, BFR=22R
everything the same, load 4R
Graphs , 4R load, BFR=22R, continued
again
I didn't investigated where is bloody clipping
Meant that 70W is already enough
Reactions: Russellc
Graphs , 8R load, BFR=510R, continued
Everything the same, but BFR changed to 510R, that being opposite extreme to 22R - practically lowest OLG which I considered
more of these
Graphs , 4R load, BFR=510R
everything same as previous, load changed to 4R
Graphs , 4R load, BFR=510R, continued
more.....
Impressive - still lower THD at 50W into 4R than many measly amps do at 1W and it's still able to stay H2 dominant. Again, many of the ones I measures start to become more H3 at higher output.
Have you done any SIT testing yet?
Do you like this one better than Singing Bush? Any comparisons you can share?
Twitchie - I did made some listening - as always - decisive step should I proceed with some construction - with Ikebana style prototype, mono
Have some excuisite mono recordings, which I know damn well, and - if my foot is thumping and I feel like crying - that's it - damn thingie is worthy further pains
( lying, as always, there is no pain in this)
so - yes, I did listen and its worthy , but usual ZMAudiophooling commence tomorrow...... I mean , regular sissy stereo approach
well, it's spooky
didn't heard SIT iteration, but I have no any suspicion how it'll sound
so, few days of fun with full MOS, including visit to my Set of Spare Ears (hopefully tomorrow) then SIT tryout/presentation/visit to SSE
edit - no way to compare this Beast to Singing Bush Beast - really two sides of same coin ........ if you can call Coin territory marking same level of high quality
yup, ZM humble , as always :rofl:
Reactions: Mikerodrig27
Iq 1A7 ...
Chance for redemption for all the failed F5T builds and won't leave dry taste in your mouth :tongue:
That's also big consideration for building this over BAF 50W (or SB) is no need for 63+V caps but is it still possible to sound like big powerful SET amp?
Only MZM knows 😀
Only MZM knows 😀
no, even if I'm sure that regular Greedy Boy is predestined to love both, these two are never going to sound, well, similar
breed thread is there, but difference in THD level is just too big ........... in fact, yes - this one can sound as big powerfulllllllll SET amp-cruising at 1% of potential
which, funny thing, is exactly how I think that Singing Bush is best used
impressive low THD+N at full power.
name of the game was to make Babelfish of XA25
so, that is it
Nirvana 😉
Mighty ZM - All I can say is WOW - what a roll you are on 😀
yup Bubba, tnx 🙂
