Flattest fullrange relative high efficiency drivers.
I'm sorry I did not notice your reply, I only just realized. 😱
Yes, I agree, the Fane are extremely promising on paper and I've planned to use them for a very long time yet I haven't so far. After finishing my 15"/3-way horn speaker I'll take them up as my next project (which I wanted for YEARS).
I am pretty sure the Fane will perform well down to 120-150Hz with a proper DSP setup.
Because of the parameters needed for a FR driver, even large FRs need or at least will profit from subwoofer reenforcement or a horn enclosure. But the very high Qts of many large FR drivers leaves no other option of an open baffle or a sub/sat setup.
Sealed or ported can be used also, but sealed it wll be 90 to 150L, and ported more about 300L with the Fane. It has been done before, and i'm planning to do it also (the ported version) but with the woodprices of today i'm going to wait a bit i think...
Well, yes, the Fane 12-250TC likes a big box.
But I did not use much DSP power to get very loud down to 40hz, used dip eq only on my think it was 110 liter boxes.
Managed about 106db worth of bass in halfspace with not much power.
Speaker grill is advised.
The 300L ported goes to about an F3 of 30Hz without DSP on max 20w (106dB), and with only a slight bump of about 1.5dB at 75Hz says the simulations i made. That is quiet decent for a driver with such a high QTS. And the port is basicly a hole of 6x17cm in the 18mm plywood of the front. The only difficulty about this is the big size and the ammount of bracing that such a cabinet need to be strong enough. I probally need about 3 big sheets of plywood and some full wood beams to do the bracing to build a pair and it will be a real wardrobe style cabinet that won't move easely.
No, the "flat" FR driver doesn´t exist apart from a few units with lots of damping in the cone. These will still need BSC and even then sound bad.
No, don´t trust most manufacturers curves or data. Most FR drivers are worse than published.
So, most FR drivers have unbalanced responses, and your box or baffle will most probably make it worse. A passive correction filter can get this into balance and, if well implemented and made from quality parts, will have no negative effects (don´t believe those who fear destructive phase effects from the filter - phase and response are coupled by fourier transformation, if you get the response better, phase follows...). What such decice CANNOT correct are breakup modes, or simply resonances, which will remain even if reduced in level, as easy to see in a CSD.
If you look for drivers of modest quality without too much treble trouble, W-1808 as an 8" (as Davor said) or W-2143 as a quite cheap 5" are solid choices, the FR drivers from SEAS are not too bad, too. The 2143 could also be part of a WAW system, or have a look at XRK´s WAW with the Scanspeak 4" FR. Don´t believe shelling out lots more of money will buy you drivers without need for correction...
All the best
Mattes
That depends strongly on the driver. More so on it's excursion if you need high spl. High excursion leads to huge distortion in the mid and treble. While you can reduce the excursion greatly by limiting the lower frequency range of the FR
The growing number of WAWs is just because of this. Bass limits expense and size related, and the FR, releived of bass, does its job midTop better.
dave
955647d1622252775-flattest-fullrange-relative-efficiency-drivers-fostex-enclosure-jpg
The best of the Fostex factory horns is mediocre at best, FExx6 series have all got better horn designs available. These drivers do need horns.
Dallas II, Kirishima, Vulcan for FE206. I prefer FE166. And the FFxx5wk more. Have a look at FF165wk if headed in that direction. All of these Fostex have some fairly easy tweaks that really helps with the speakers issues.
dave
Pp
I typically avoid volumes larger than 240 liters or so because of this.
For me, I consider it somewhat a waste to make a volume over 180 liters per driver. If there are several drivers it's 240 liters per volume. Especially on a FR unit since it starts getting tricky to avoid internal reflections.
My closed volume for the 15-300TC is about 80 liters, internally the chamber is divided by solid walls at angles to help break and dissipate reflections. Nothing complicated, just some boards and various types of dampening material.
Even the Seas Exotic (more than 500uss each) in a pdf of the company gives the data of a passive network to improve the response.
It remains at 90 91dB. In Klang Ton magazine they establish the same and a passive network with similar values.
There are the pdf from Seas and Klang ton.
Alpair 12p is maybe of the flattest ?
Go a picture from the Seas Exotic.
