MOSFET 2SJ118/2SK413
Hello
I have a problem with the ACCUPHASE P-266 power amplifier. The 2SJ118 / 2SK413 mosfet transistors were burned. I know that these transistors ceased to be produced a long time ago. I have a question, does any of my colleagues have such transistors in their inventory somewhere? I need a set for one tip, i.e. 3 pairs. Maybe you know where I could buy them? Thank you very much for all help and best regards
Gregory
Hi Gregory,
What I would do is substitute something current you can buy through proper distribution. I haven't looked for a sub for you, but that would be my first option. Buying from the manufacturer is a good option. Buying from Ebay is your absolute last option.
In a last ditch effort, you might have to buy a parts unit. I just did that for a transformer in a Sansui AU-717. The lengths you have to go to will depend on how much your customer is willing to spend, but remember your search time is also billable.
Hope that helps you a little, Chris
Edit:
Here is a data sheet for you: 2SJ118 datasheet It looks fairly common, so replacement with something current shouldn't be such a problem.
The 2SK413 differs from standard spec. mosfets in speed =50/110ns , I wouldn't buy from Ebay either , 2SK1057/8 are very near but I think obsolete also .
Its easy to "head East " but not for me and yes 2SK1057 are available there .
Hi Gregory.
I have 2 pcb from a very old project i never have finished they are mounted with 2sj118/2sk413 and are 100% original parts if you are interested you can have them all for 40 euro + shipping to polen, i live in denmark.
Best regards lau
Grzocho - if Uglykid is offering what look like original era PCB,s with that amount of original mosfets at that price I wouldn't even hesitate in case somebody else here has a 5 second think and realizes how much of a bargain that is .
Hi Gregory.
Best regards lau
I am interested in your offer and I want to buy transistors from you.
uglykid
How can I contact you?
Write a private message regarding the transaction.
2SJ118 / 2SK413 are NOT lateral MOSFETs!
They are more like verticals, but not quite...
The pinout is different; pay special attention to drain and source and which one is connected to the metal flange.
The specs are different; for example, pay special attention to the zero tempco point for ID vs VGS.
DON'T buy laterals like 2SJ162/2SK1058 (or other similar parts) expecting to drop them into your amplifier successfully without making mandatory changes.
Save some $$ and grief - please consult the Hitachi Power MOSFET Databook first before you do anything!
http://www.bitsavers.org/components/hitachi/_dataBooks/1985_D11_Hitachi_Power_MOSFET_Data_Book.pdf
Reactions: anatech
