Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
Hi Vitaly,
Thanks for some explanation.
Please give configuration details for all the circled header pins in my pictures. What is the purpose of the red jumpers?
Is the faston tab (J25) a earth/chassis ground connection?
Is J3 for fault indication?
Just a suggestion, if you add a detailed hookup diagram and the Akita amplifier schematic to your first post, you wouldn’t have to keep answering these questions. The more amps you ship out, the more questions your going to get because the information is vague and in some cases non-existent.
Thanks,
Vunce
Hi Vitaly,
Thanks,
Vunce
There is the PCB mass with me ...
See photo
Hi all!
I finally found a moment to test the vitaly akita amp ... With a usb dac, it seems very promising.
All is well! I did not give him a gift, no protection from the amp ... Unlike my Chinese amp!
In short, I am super happy !!! (it was worth the wait)😉😉😉😉
Thanks for the pics Cardone. I checked with my DMM, there seems to be approximately 20R resistance from either a resistor or NTC between the J25 faston and the aluminum baseplate, probably as a Ground Loop Breaker.
You have no ‘hum’ issues at all, correct?
I will feed a balanced signal to the Akita from my BTSB SE—>Bal converter.
But, I’d like clarification from Vitaly if the jumpers need to be reconfigured.
Also, is there an auxiliary 12v power output on the Akita?
AUX 17v +- left side before stab
you see first red jumpers closed right pair - replace for closed left pair
After this, inputs = A-, center GND, B+
and C-, Center GND, D+
Thank you for the supporting info Vitaly!
Referencing my attached picture.
- Move #2 jumper to the left for balanced input.
- What is #1 jumper used for?
I’m looking forward to getting some sound from this little guy.
Thank you.
