Cardone, as recommended by Vitaly you have to try Ada 4610-2 😁😁😁
I'm just telling you one thing Nerone, if we continue like this then we'll be like the tubes amplifier boys ...😀😀😀
But I enjoy it ...😉🙂
Everyone tells me that the amplifier starts to work well after 50-70 hours.
Because of Elna Silmiс
Hi Vitaly,
Thanks for some explanation.
Please give configuration details for all the circled header pins in my pictures. What is the purpose of the red jumpers?
Is the faston tab (J25) a earth/chassis ground connection?
Is J3 for fault indication?
Just a suggestion, if you add a detailed hookup diagram and the Akita amplifier schematic to your first post, you wouldn’t have to keep answering these questions. The more amps you ship out, the more questions your going to get because the information is vague and in some cases non-existent.
Thanks,
Vunce
Thanks,
Vunce
OK...
But I think that the powerful bass of the 627 stays that way even after 50 hours ...
I'll put the 1656 back on it next week ...
I like it better and also fits my Teufel speakers ...😉
Hi Vitaly,
Thanks,
Vunce
There is the PCB mass with me ...
See photo
Hi all!
I finally found a moment to test the vitaly akita amp ... With a usb dac, it seems very promising.
All is well! I did not give him a gift, no protection from the amp ... Unlike my Chinese amp!
In short, I am super happy !!! (it was worth the wait)😉😉😉😉
Thanks for the pics Cardone. I checked with my DMM, there seems to be approximately 20R resistance from either a resistor or NTC between the J25 faston and the aluminum baseplate, probably as a Ground Loop Breaker.
You have no ‘hum’ issues at all, correct?
I will feed a balanced signal to the Akita from my BTSB SE—>Bal converter.
But, I’d like clarification from Vitaly if the jumpers need to be reconfigured.
Also, is there an auxiliary 12v power output on the Akita?
No ... I haven't made any changes to the crowd ...
I left it like that ....
The only thing is a slight plop when switching on ...
Otherwise all is well ...
Hi all!
Sounds good..
Please take care of the spider .....😀😀
The mamocel and Vunce card is different from mine and from Cardone's, perhaps it depends on the fact that we ordered a 2.0 different from the 2.1 and with balanced inputs.
This is the main amplifier tester)))
AUX 17v +- left side before stabI will feed a balanced signal to the Akita from my BTSB SE—>Bal converter.
you see first red jumpers closed right pair - replace for closed left pair
After this, inputs = A-, center GND, B+
and C-, Center GND, D+
J6- reset pins, if closed- amp in reset mode
J3 out pins for led, clip\OTW and fault
J25 this is GND
J25 this is GND
Hi Vitaly, Akita is great with 8 ohm speakers, are there any modifications to improve the 4 ohm?
Thank you
Thank you
😉Thanks! Vitali!
Your amp is above everything!
Nothing to do with Chinese tpa !!
I have no regrets .... and proud to have a Russian amp at home.
Continue in your projects. You have the ears and the talent ...
Thank you from the heart !
Thank you for the supporting info Vitaly!
Referencing my attached picture.
- Move #2 jumper to the left for balanced input.
- What is #1 jumper used for?
I’m looking forward to getting some sound from this little guy.
Thank you.
- Group Buys
- Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
