I have salvaged two 5" drivers from a Polycom Cambridge Soundworks Subwoofer - C1PLY24R.
Does anybody know where I could get any info on these drivers. I was tempted to get rid of them but original system cost a fortune. If they're any good I might use them in something.
Tell us what it reads on the magnet cover and look for a number of the back of the cone as well.
1208ZX
Nothing visible on the back of the cone.
I wondered if anybody would recognise the driver as Cambridge Soundworks manufacture for Sony and Marantz.
Is there such a thing as a 5 inch subwoofer= - seems it would be a little short on cone excursion
For small apartment or near field use, small = fine.
e.g. if you built a 1-person sound system into one of these, the sub could be right behind your head.
DIY Ovalia Chair Serves Your Futuristic Fantasies | Hackaday
You wouldn't want or need a huge driver.
Depends on enclosure and LF cutoff needed. If it only needed 40hz extension with low power it won't need a lot. There were 2 in those subs so you need half again
Sub is a very loose term these days. What the OP has is a pair of nominal 6” woofers used in a powered bass box. If they were kind enough to put some numbers on the back of the cones, we would have a much easier time helping out here. Maybe someone out there recognizes them. I had some similar Wharfedale units they only looked the same.
Whilst there is virtually no domestic component market, changes in popular music and Hi-fi systems have conspired to advance small drivers. The advent Midi / Micro systems coincided with the rise in popularity of hip-hop music forced manufacturers extract serious bass from tiny bookshelf speakers. Take one of those small systems apart and you'll find some of those 4" bass drivers have some serious cohones.
Even the cheap 2.1 computer speakers have subs with 4" drivers that respond to 40Hz.
Popular low-end AV systems use 5" subs.
In short, yes, a 5 inch sub is a real thing.
- Subwoofers
- Does anybody recognise this driver?
