I am looking for a source for Phono Preamp grounding post's. Looking for a new parts supplier that has a couple sizes/styles available.
anyone know of a source? Preferably USA based?
Zc
Zc
A knurled nut on a 3 to 8 mm screw, both in brass or plated brass should work.
In inches, 1/8 to 3/8 of an inch...
Select one that suits your wire or lug.
Sometimes used in car electrical parts.
Thumb Screws & Nuts - Knurled Thumb Screws - Captive Thumb Screws
You might have to buy through a dealer.
Now I use binding posts because it was when I could not find a good ground screw and the ones I found were ridiculously expensive. But what became an extra good discovery was that my ground cable got a banana plug mounted because it became easier to mount and disassemble.
I'd order whatever size of McMaster-Carr
I wanted to use.
I usually choose a #8-32 screw passed through the case and locked down with nuts. Then the brass knurled nut is used to secure the wire or lug to the stud. Easy and cheap.
I wanted to use.
- Design & Build
- Parts
- Looking to source Phono Preamp Grounding Post's
