Power tube supply voltage drop
So i took the isolation transformer and my analog scope, 10x attenuation on probe/10V per div. Measured from the leads of power trafos 250VAC secondary, while connected to bridge.
First the reading on my multimeter.
Second the waveform right after power up. (cathode still heating)
Third after the current starts to flow.
So looking at the circuit you posted in post #14 you should be seeing the value of the flat topped part of that AC voltage as appearing across C5. There will be ripple but the bridge output has to rise to that level (less diode losses of course which will be under 2 volts).
(A 1 to 1 isolation transformer will probably have significantly higher output at low loading)
From little load (only filaments) to full load, peak voltage (which is the value to which capacitors will charge) loss, is 20%
A SIGNIFICANT loss.
Yes, I enlarged the image and counted divisions.
If you measure from NO load (not even filaments connected) to FULL load, difference will be even larger.
BESIDES: a regular multimeter will NOT measure the second waveform and the third one the same way, so we can not consider "250V" displayed on both cases as meaning the same, even if "numbers" match.
To be more precise: whether I measure both waveforms with a true RMS meter, or a cheaper "Average factored to RMS", if both display "250V", capacitor DC voltages will be different, lower in the flat topped third one, because it will have lower peak value.
Like 6A3Summer said , an old fashioned VTVM will give better results, because they measure peak voltages.
An old fashioned analog/needle type meter, will show average-factored-to-RMS voltges, because of moving coil and needle mechanical integration.
A Scope will show the full picture. (duh! 😛 )
A Shower will clean you well.
