Building a Williamson EL34 amplifier
A few ways to include/exclude your hum/noise. For example,
- battery power the heaters.
- temporary short across the pcb signal input terminals
- pull out V2
- do all of the above with and without GNFB connected
- measure what your GNFB level in dB is (ie. if you are only applying 6dB feedback, then increasing that to 12dB may drop your hum by 6dB - but you then should preferably measure your stability margins)
- how well did you balance the EL34 cathode currents? (and btw how do you access the bias trimpots?)
- what are the dc circuit voltages at idle (eg. mark up the schematic)?
But you should aim to use a meter or hum level benchmark measuring of some sort to determine the change. The better method imho is to prepare soundcard/laptop/spectrum analyser type measurement tool, so the hum frequencies and their magnitudes can be identified.
Are the brown wires going to the pcb (near the input signal wires) the output wires used for feedback? As they have a relatively high signal level on them, it may be preferable to distance them as much as possible from the input signal wiring, and to separately shield them on their way back to the pcb (to avoid cross-channel coupling and stray pickup). Is each output grounded separately at the pcb common gnd point? It may be better to ground each speaker output directly to the ground end of their respective R2, although that may depend on pcb layout as the speaker ground would carry parasitic capacitance current from the output stage main signal loop.
What are the two power transformers specifically for? Do they have a large steel washer between the core and (aluminium ?) chassis ?
I've re-routed the input cables.
The amp is now silent until I turn on the pre-amp.
I don't get any hum at all with either of my Alephs.
I gave up on unbalanced grounded signal cables years ago, on ANY audio equipment t which uses a three prong plug. Not everything has truly balanced inputs but every piece has either differential or transformer isolated inputs. I will never run the audio signal return though the shield, period. Everything that is intended to drive something with a three prong plug has active balanced outputs, except for the few lower end Pro pieces that only have impedance balanced and I haven’t torn into them yet. It’s not worth it to spend a bunch of time building something nice, then fight with a ground loop. Design the solution in and be done with it.
If it’s silent with nothing plugged in the amp, then hums as soon as another device is connected it’s a ground loop. I’ve even had ground loops that don’t make physical sense - With no obvious path - and putting in the damn transformer fixed them every time. So did plugging it into an extension cord with a missing 3rd prong (so I know it was a ground loop) but if you do that DJing a school dance and someone finds out you never work again. Now I simply won’t give a piece of equipment the opportunity to annoy me.
WG_SKI.
The only reason that I went down the "balanced" route is because I built the Aleph 4 and the Aleph J which both are balanced designs.
The Aleph 4 really benefits from having a balanced input, if only to achieve its stated output.
Hence the pre-amp is a balanced Aleph P1.7.
I had to build a John Gilmore Unbalanced to Balanced convertor to take my unbalanced sources and convert them into balanced inputs for the P1.7.
While I am waiting for the two 10K:10K transformers to arrive I might just try building a simple passive attenuator and see what happens if everything is unbalanced.
