Inductance meter
Looking for a meter to measure inductance; specifically 130uH. I already have a nice Fluke digital meter for measuring voltage, resistance, and current; and I have a good B&K capacitance meter. But I need an inductance meter that will measure down in the uH range---don't need the other measurements and don't want to spend a lot of money. Any suggestions?
I own and use six different inductance meters, at price points from USD20 to USD700. The one I use and rely upon the most, is a brand called "DER-EE" and a model called DE5000. It's sold lots of places but the best value for USA buyers is eBay. Get one that is bundled with ALL the accessories, especially the tweezer option. You won't be disappointed.
.... The one I use and rely upon the most, is a brand called "DER-EE" and a model called DE5000.....
That is the DE5000 that was posted in the link above. I have one & it works well. It is physically larger than it appears in the picture.
  • DE_5000.pdf
    DE_5000.pdf
  • DE_5000_Manual.pdf
    DE_5000_Manual.pdf
If you happen to have a Quasimodo or Cheapomodo test jig, they measure inductance quite readily. Apply stimulus, measure ringing frequency fR, insert fR and Cx into parallel LC resonance formula ---> shazam, out pops L.
Got an am radio? 130uH will resonate at 1,040kHz midway through a 365pf variable capacitor. Make a one transistor oscillator with the inductor and variable cap, set the a.m. radio to say 1MHz, sweep the variable cap until you get a beat, measure the capacitance and the inductance falls out from the math.
Everybody should have a voltage network analyzer. The "Steber" Impedance Measurement Set used a sound card and a quad op-amp -- unfortunately, the software was circa 2005 but there are variants on the web: ZRLC
If you would like the original QEX article PM me as it's now behind a paywall.
Believe it or not, somebody is still building and selling brand new grid dip meters. I happen to know this because I bought one last September. The device is "MFJ-201" (sometimes listed without the hyphen) and I paid just under $200 for mine.
link
I also placed an order with that seller. Be interesting to see how well the LC100A measures. I figure I can check its accuracy by using my HP AC voltmeter, HP oscillator, a capacitor with known value from my B&K cap meter, and some mathematics.
