FPGA-based delta sigma DAC
just use some I/O to be delta sigma output or discrete FF (like a CHORD 😀)
After that, the signal directly come to analog filter.
I think use FPGA, we can provide balance signal with dc offset
Which of the two do you use: just an FPGA I/O or an extra flip-flop? With an extra flip-flop, you basically use the flip-flop rather than the FPGA as the DAC, and you have much more opportunity to limit crosstalk.
I don't quite understand your last sentence. Do you mean you generate a balanced output signal and then convert to single-ended (if needed at all) after the analogue reconstruction filter? Using balanced outputs and return-to-zero coding can much reduce the data dependence of the current that you draw from the reference supply.
Clocking Hell.
Err I mean each of those three FPGAs will have it's own master clock and you need a sync clock.. and the bit stream clock.
I thought the easiest way was to run a set of shift registers and then sync the switching as one. They would be cheaper than using an FPGA for the same role - that way you only need one. Which is pretty much what most of the FPGA R2R DACs do.
This design I only use FPGA, as per CHORD, they use FF NC7SZ175 😀.
DS out is 0 or 3V, so DC offset is a half.
So each channel, output will have 2 signals.
You can see my draft for more detail.
* I draw too bad ...
It looks like you use linear interpolation. If that's true, then how do you compensate for the sinc^2 roll-off? It's quite substantial at low sample rates, for example -6.3356 dB at 20 kHz at 44.1 kHz sample rate.
:wiz: you're right.
In my project, CIC interpolation need add FIR compensation
The cost of each FPGA is quite high, at least US$100, or even US$300. In addition, the noise of the FPGA itself is higher than that of the DAC chip. The DAC HAT of iancanada using ES9028Q2M is only $49.00. In other words, if your FPGA-based DAC is not as good as ES9028Q2M, even if everyone wants to sponsor you, I am afraid there is no way.
There aren't three FPGAs on that board. There are two CPLDs and one FPGA. The two CPLDs do not have the resources to do much more than replicate the role of the HC595s.
The CPLDs I've seen have been titchy compared those. You can do PWM for example at very quick rates using a CLPD, but as you've said they're very limited without ADC or internal resources.
😀 not expensive as you think
Based on fpga that you choose and quantity you buy
ESS 9038Pro is already a very powerful DAC chip. If you use a cheap version of FPGA to implement the DAC, I would not expect yours to be better than the DAC chip. Chord DAVE uses the LX75 version of the Spartan 6 FPGA and three more.
https://www.newark.com/xilinx/xc6slx75t-2fgg484i/fpga-spartan-6-268-i-o-fbga-484/dp/32AC9780
Iancanada's the reclock module uses Altera Cyclone IV. So if you want to implement a much more complex DAC, you can only use a larger and more advanced FPGA, right?
ha ha ha ha, About FPGA, We never know how much resource has used. Large FPGA is not meaning if We not use all... Small FPGA is not simple DAC. It is based on algorithm.
:cheers:
@yunyun
There are many DACs, amps, speakers...already made, so what's the reason for diyAudio and other comunities, let's close them.
Just DIY project. Let's have fun
:cheers:
I'm printing a chassis for our project, let's wait...
According to the BLOCK DIAGRAM of 9038PRO and 9018, it can be easily seen that in order to achieve better sound quality, a larger FPGA or even more FPGAs are needed to accommodate more complex logic units.
In other words, if your FPGA-based DAC only uses a relatively small FPGA, it is not difficult to know that you do not intend to design the performance to be stronger than the existing DAC chip. In other words, it's just for fun, not to get better sound quality.
@yunyun
Many years ago, I actually spent money to compare ACKO and iancanada modules. In the end, I convinced ACKO with theory that his module was totally unsuccessful. ACKO asked me to pay him some fees and let him continue to develop. However, why should I do this? Isn't it more in my interest to buy the iancan module directly?
I'm sure a very basic FPGA-based DAC can't compete with the highest SINAD DAC chips on the market when the only thing you care about is how many dB's of SINAD you get per dollar, but then again, what difference does it make whether the noise is 10 dB or 100 dB below audibility under normal listening conditions?
Regarding benefits, XC6SLX9 FPGAs have many:
-They are relatively cheap
-You can still hand solder them, unlike the bigger ones that are all in ball grid array packages
-As with any FPGA, you can tweak the configuration file, so instead of tube or op-amp rolling, you can do configuration file rolling
