E55L Parafeed Spud Design - Your Thoughts
Joined 2004
Try this.
It's enough close to the real curves.
.subckt E55L p g k
;Rydel's Models Triode Mode
+params: gp=0.004735979219 b=3734.604234
+ c=0.3266713215 d=79.54627249
+ cgk=11p cgp=5p
+ cpk=1.8p mu=30
e1 1 0 value= {1+(v(g,k)/b)}
re1 1 0 100meg
e2 2 0 value= {v(p,k)/(v(p,k)+c)}
re2 2 0 100meg
e3 3 0 value= {v(g,k)+((v(p,k)+d)/mu)}
re3 3 0 100meg
g1 p k value= {gp*v(1)*v(2)*(pwr(v(3),1.5)+pwrs(v(3),1.5))}
rpk p k 100meg
c1 g k {cgk}
c2 g p {cgp}
c3 p k {cpk}
.ends
Joined 2004
Don't forget to use ferrite beads.
High gm pentodes tend to oscillate even in triode mode.
Joined 2019
Here is my adjusted load line and schematic.
Curves traced with 2.5K LL, 170Va, 55mA.
Approximate schematic (doesn't fit real-world curves exactly). Cathode bias with the OPT primary returned to the cathode.
Think this is better, and easier. And will use ferrite beads, euro21 ;)
This.
Especially considering that finding an appropriate size choke for this project is actually pretty easy.
On the other hand, CCSs are cheaper than a plate choke and they would eat enough of the ripple and noise from the PSU that you can probably get away with a single RC filter after the rectifier.
You just have to deal with the heat.
Joined 2019
I am using a spare transformer for this project, 325VAC, a choke load is not practical with it.
I see the additional PSRR as only a benefit, which will reduce the number of components needed in the passive supply. The OPT will also have headphone output taps.
Other than the heat, which is accounted for, what is the downside?
Joined 2004
IMHO the downside is the parafeed itself.
About a year ago I tried -as breadboard- the E55L parafeed layout, but it wasn't better (measurement), than OPT loaded E55L spud.
BTW the tried 1:1 -Slagle- interstage almost as costly than an OPT. :-(
An IXY by itself will have an order of magnitude higher impedance and lower parasitics than any OT so its impacts on the overall sound will be swamped. It can also cope withe the dissipation adequately if heatsinked. A stacked CCS is just overkill in every department.
Shoog
Joined 2019
Shoog
Well thanks Shoog, I'll take a look, do some simulations. I was more interested in the increased ripple rejection that could be attained in cascode and reducing the number of passive components in the supply, but perhaps it isn't necessary, will report back.
Joined 2019
That is quite the diode string, euro21. In what way was the parafeed setup inferior? Very happy with my 45 parafeed SET. I know many do not like the reactive load, but substitutes high quality cap into the signal path as opposed to last PSU cap and simplified power supply with good PSRR. Bonus for me is I have a Sowter mains transformer appropriate for the project, with CCS load as opposed to choke.
