Multi voltage power supply rail
I have observed that in tube electronics different B+ volages are set by resistor networks, followed by capacitors, for each voltage.
I have a solid state preamp that requires +23@135mA, +5.6V@95mA and -12V@9mV.
How bad would it be if I have a stiff 35VDC power supply with a resistor network, consuming 0.5 - 1A and tap it to get the voltages I need?
This maybe an obvious solution. I am asking because I never see it used in solid state projects.
Thank you.
> if I have a stiff
How stiff is "stiff"? 10%? 1%? How dynamic is the load? 134mA-135mA steady, or zero to 140mA every thump of the bass?
10% stiffness on 135mA load wants about 1,350mA in a resistor divider. That's 47 Watts of heat to get rid of.
And what "preamp" needs these three odd values? 1959 broadcast line driver? With an ECL kicker?
Technics RS-9900
No, it is cassette recording and playback amp. The power supply (and bias oscillator) is in the mechanical section, which I do not have. I use it with other devices that run at 1-7/8 ips.
Current demand appears to be very steady.
Discrete SS preamps also do that, all the time.
Only Op Amp circuits tend to demand ubiquitous +/-15V or thereabouts,but clearly that´s not the case here.
OK.
Forget wasteful brute force resistor chains.
If you start with a +35V supply:
* use a 24V regulator such as 7824 for the "23V" preamp.
Heat sink it, it will dissipate some 1.5 W all the time, so a small U type one will do.
* for 5.6V use a 7805 with an 1N4002 diode between "ground/reference" leg and ground . It will dissipate 2.8W so surprisingly will need a larger heatsink than the "main" circuit, a small 30x30mm or so finned one will do.
or a larger U type.
* no way you can get negative voltages from a +35V only supply so you will need some source for that.
You give us NO details about your "35V supply" .
IF a conventional transformer+bridge+large capacitor you can kludge a -12V supply since it is low current.
IF it´s an SMPS brick, you can not.
When/if we get more details about your actual supply we might suggest a couple other solutions, but so far ....
