B1 r2 proto or prod?
It sounds FANTASTIC! 🤩
Big THANKS to Nelson for sharing the schematic! 🍻
:grouphug:
I've built a B1 R2 using the same board as Peppennino. I've used components with the same values as Papa's schematics.
How do I adjust the P101 and P102 for correct performance? I've read through a few threads but haven't found an answer. Jfets are matched Linear Systems, grade B from the Diyaudiostore.
I'm guessing I adjust P101 for V measuring across R101?
P102 is adjusted for 0 DC?
Reactions: schultzsch
anythng from 470K to 3M3
it's there "just" if volpot starts loosing wiper
https://www.diyaudio.com/community/threads/b1-r2-proto-or-prod.363274/post-6435903
:cuss: :deerman:
So, if using a resistor attenuator like the Frontpanel from glassware, I get that this part is probably needed anyways. But will I have a bit more headroom wrt choice of values? Parts bin is dry above 68k.
Planning to try Picos way, got some breadboarda today.
This will of course tell me maybe 2% of what the pumpkin is all about, compared to 0% as is. Plus improve my gain structure.
Andy
Bere I am 😀
I'm waiting for R1 and R2...
Hi Peppennino,
I was looking at your cool case for your B1 rev2. I notice the switching and volume pot extensions. How did you do that? I'm wanting to do that with my build and not sure where to buy the stuff that allows you to have knobs on the front of a box but move things or switch things toward the back of the box? I'd appreciate your input. What do you even call the added tubes and supports-- in other words if I went to digikey or someplace, how would i even find those extensions, etc. THANKS!!!
hardware store, 6mm material
dunno how it's called in your neck of woods, wire, shaft, stud, bar, rod
heck, you can even use M6 threaded rod, usually sold in 1m length, though proper round 6mm will give less wiggle in front hole
and then you can dismantle old broken pot, and use its front as sleeve bearing for front plate
illustration: https://www.amazon.co.uk/PACK-METRIC-THREADED-STUD-ROD/dp/B07DK9CRG9
Reactions: GndSense
