Tone controls are necessary in audio systems
Oh get off it with that "offensive" crap already.
The masses are tired of hearing such blabber.
Or don't you read the news?
Try to understand, you are not writing for the masses here, this is a forum specialized in audio, although it seems that some people boast of their limited knowledge, they are accepted. But from there to offend by generalizing ...... that's very ugly! please comport good !
And yes, I read the news, the impechment failed, for example ......
Which one do you mean, do you think I'm a fortune teller?
Okay so the op is way too arduous and tedious to work through in it's present condition...imo. I wonder if Richard has changed his mind since then considering some very high quality and expensive gear has come about with no tone controls since that paper was written, the rationale being less is more. The fewer circuits the signal passes through the less degraded it becomes at it's final destination. Maintaining purity of the signal is clearly the goal. Whether this is measurable is questionable but only to the particular amp/pre at hand. Adding or removing controls and then listening would reveal how beneficial if at all they could be. But they would have to be set to flat for a comparison. Comparison of what? Obviously not frequency response differences. So somebody came to the conclusion that tone controls somehow compromise the overall sq enough to delete them. Naim comes to mind. Early Boothroyd Stuart Meridian also.
Pretty good sounding gear.
Curtains, blinds, upholstery, carpet all serve to enable a decent sound stage.
Everybody has their priorities.
So are tone controls necessary? No...imo
I agree, and would add that of current tube amps, I think even MC Intosh has removed the tone controls on many of their models, which means something ......🙄
That phrase is offensive and unnecessary ...
Its quite amazing what sound some people will put up with.
I ran a mono mobile disco for 40 years and no one ever commented it wasnt stereo.
In the first few years before I got a mixer the speakers only worked up to 3KHz.
Again no complaints.
Never mind the quality, feel the noise.
Every disco that I went to, NOBODY there critisized things like IF it was stereo sound or not.
People went these to party, mingle, and drink.
Why should anyone care about the sound at such a place?
I should mention bass response is where the vast majority of eq is beneficial and my system is no exception, namely a pair of Acoustat Monitor 3 ESLs enhanced with a pair of Linn 5150 subs, ABSOLUTELY REQUIRED...imo😀
we all have our priorities
I also use sobwoofers, but to achieve an extension to the bass response of the system. No tone control will do it, they only reinforce what is already there, sometimes for the better, sometimes for the worse, it depends on how it is used.🙂
The Acoustats are flat to 30hz, the 5150s to 15hz. I just replaced my other Velodyne subs that were flat to 26hz. You would think that should have been sufficient. Both have built in 200watt amps in each sub but the Linns go subjectively right to the bottom cleanly. They are awesome! I know there's no information down to 15hz but the capability and therefore the F3 response of the Linns, whatever that is, gives them serious spl down there.🙂
That seems to be very good, I have reached 20 hz "flat" with DSP because I could not (nor did I put too much effort) to fully unravel the software of the Bheringer NXEdit. It seems that to go below 20 Hz (by default) you have to dabble in the parametric equalizer, but first you have to cancel the chosen crossover, and then ....... oh, I'm starting to lose my enthusiasm in all this, damn pandemic ! 😡
