Hornresp
Glad you took the pain David 🙂
Not enough pain, it seems... 🙂.
On further testing, I have discovered that strange things can happen when absorbent filling material is added. I am currently trying to work out why this should be so, but it is proving to be a difficult task. The interactions between the various sliders are now so complex that it is hard to keep track of what does what and when. The whole loudspeaker wizard model appears to be teetering on the brink of becoming unstable.
Once I identify what is actually causing the problem, the next challenge will be to come up with a solution, which may be easier said than done. I will keep you posted on developments.
Well get again this error invalid argument.
Can not find this cause, it does it rarely.
I can't close menu driver front volume anymore, need to control alt delete.
regards
Hi Kees,
Thanks for the feedback.
The nature of the error and the fact that it only occurs intermittently would suggest that there is something about your computer that Hornresp does not like. I can see no reason why the Driver Front Volume form should not just open normally every time. There is nothing in the code responsible for loading and showing the form that should trigger the error you are seeing.
Everything continues to work okay for me.
Kind regards,
David
Hi Kees,
Kind regards,
David
Hi David
The driver volume vorm does just open fine, it happens when I try to close it, the button does nothing anymore and need a control alt delete.
I have no trouble with other software also not with LTspice or so, but maybe there is a dll share with other program who can do give trouble sometimes.
regards
I think I am right but little confusing.
You are correct - the chamber air volumes on each side of the driver diaphragm need to be specified as shown in yellow in the schematic diagram. This is because as far as the simulation model is concerned, Hornresp knows nothing about the physical dimensions of the actual driver, apart from the Sd value.
Ready to build...
For completeness (and some depletable pride, being honest), here's the final design and Hornresp inputs/outputs for my first go at a speaker design. Thanks to David and others for all the helpful input. One note: To keep this first project reasonably sized, I decided to target the low corner at 100MHz even though the Dayton Audio PS180-8 has a Fs of ~80MHz. But the BLH fires rearward/slightly downward at a wall.
See one play one:
This is not to large.
The ripples are not really audible from experience in designing a lot of these. And the 5 db shelf is mitigated if you put the mouth at the rear and near a wall boundary.
Model it in 1 pi and see what I mean.
The mighty Klipsch horns had response that stopped at about 65 hertz and little else. I have designed better versions for one client.
These will knock your socks off if you have a lowpass filter set correctly. You can add modest gain to get to 45 db if you are careful.
Play. Maybe you will be inspired.
Hornresp Update 5130-210130
Hi Everyone,
CHANGE
Band pass system port tube end correction lengths are now shown in the status bar panel at the bottom of the Input Parameters window when the mouse pointer is moved over the Lp1, Lp2 or Lp3 port tube length input boxes.
Knowing the end correction lengths allows some loudspeaker designs to be specified multiple ways in Hornresp. For example, with resonances not masked the five different models shown in the attachments below produce identical results. Absorbent filling material can also be included in parts of some of the models if required.
BUG FIX
A number of problems identified in the Loudspeaker Wizard have now been fixed. Post #11581 refers.
Kind regards,
David
