Shanti Dual LPS 5V/3A , 5V/1.5A
Multi-channel
The units will come with XLR and RCA input.
The gain will be selectable 10db , 13db and 20db
I am still trying to implement another gain ...on voltage (+- 3db)
Antipop on power on/off.
Price will be very competitive but I don't have an exact number yet.
I'm looking for power amp modules for use in surround situation.
Ideally, it would be 8 channels with XLR inputs and SpeakOn outputs.
(the front 3 will be Purifi or Hypex for higher power).
The lower heat in Class D amp are great .
@CDSgames-loosing audio & getting white noise
hi, need some help for my problem.
Running Audirvana on my MacBookPro and streaming wifi to my router and CAT 7 to Allo USBridge Sign. with Shanti LPS.
OS is moOde 6.7.1 and the system was running for the last 9 month without any problems.
Since a few days/weeks I experienced more and more problems, like spikes/popps when switching tracks (sounds like static charge) and now is it getting worse with loosing the audio signal totally and getting a kind of white noise.
When I stop the playback and hit play again, it is gone, but comes back after some time.
Have not changed anything in the last 5 month. Beginning of August I did the last OS moOde update to 6.7.1.
My troubleshooting so fare had concentrated on my network and all connections.
When I connect my MacBookPro to the DAC, no problem at all. So I think I can eliminate the MBP and Audirvana as a source for the trouble.
I reinstalled the moOde OS as well, but no difference.
It seems to happen more often when playing Hirez (24/96 or 24/192). I'm streaming Qobuz mainly.
So I assume it is either the 5V Shanti powersupply or the USBridge Sig itself.
1.) What can be the reason for such a loss of data signal and course the white noise hiss.
2.) Could it be, that is starts to happen more, the longer (and warmer) the USBridge is running?
Please help - Thx.
@cdgames: will Boss 2 be a network player or just a DAC? If the former, any indication of price?
You will need to use the Boss 2 on top of a raspberry Pi (I assumed that the 2 is similar to the Boss1) so the combo will be a Network player. You can use various software like Ropieee and others to use the combo as a streamer. Regarding price I do not know.
Antônio
................ snip ......................
............................. snip ...................
I assume you've re-started your router at least once....
Based on your description << Running Audirvana on my MacBookPro and streaming wifi to my router >> can you exclude the Mac laptop (and Audirvana + QOBUZ) and experiment with a different set-up...?... like:
- router
- USBridge Sig + DAC
- music source from NAS or external USB storage
- LAN connection (and later on, WiFi connection)
It would be helpful if there is a new MoOde build and configuration for the alternative test described above. You may recourse to the services of a hairdryer for exploring a malfunction caused by excessive heat but BE CAREFUL and keep the hairdryer 1 metre away from the devices and use it with 'bursts' of hot air not longer than 30 seconds.
- router
@CallMeMike
It is the same, when I use mconnect app and stream directly Qobuz to moOde per UPNP. This way MBP and Audirvana is eliminated as well.
I have a Lyngdorf TDAI 3400 on loan. This amp has build in streaming device and when using Audirvana/MBP with same network/cables etc, there is no issue at all.
