The units will come with XLR and RCA input.
The gain will be selectable 10db , 13db and 20db
I am still trying to implement another gain ...on voltage (+- 3db)
I hope the voltage gain will also make it to the final version! Very interesting stuff
Multi-channel
I'm looking for power amp modules for use in surround situation.
Ideally, it would be 8 channels with XLR inputs and SpeakOn outputs.
(the front 3 will be Purifi or Hypex for higher power).
The lower heat in Class D amp are great .
Antipop on power on/off.
Price will be very competitive but I don't have an exact number yet.
Buy an Allo monoblock for each channel
Is the amp finalized yet, and if so when do you expect it to be available?Wait until you hear it..
Any update on Boss2 availability?Boss2 driver was accepted 14 days ago in Rasbian .
We are moving with production .
If everything is going to plan (and it never is) , I will say 3 months to market.
Sooo around Feb at the latest right?
Woops I did not mean at the latest, meant at the soonest haha.
All right!I am waiting for the PCB house to send the latest revision . I will update in Jan once I test it.
@CDSgames-loosing audio & getting white noise
hi, need some help for my problem.
Running Audirvana on my MacBookPro and streaming wifi to my router and CAT 7 to Allo USBridge Sign. with Shanti LPS.
OS is moOde 6.7.1 and the system was running for the last 9 month without any problems.
Since a few days/weeks I experienced more and more problems, like spikes/popps when switching tracks (sounds like static charge) and now is it getting worse with loosing the audio signal totally and getting a kind of white noise.
When I stop the playback and hit play again, it is gone, but comes back after some time.
Have not changed anything in the last 5 month. Beginning of August I did the last OS moOde update to 6.7.1.
My troubleshooting so fare had concentrated on my network and all connections.
When I connect my MacBookPro to the DAC, no problem at all. So I think I can eliminate the MBP and Audirvana as a source for the trouble.
I reinstalled the moOde OS as well, but no difference.
It seems to happen more often when playing Hirez (24/96 or 24/192). I'm streaming Qobuz mainly.
So I assume it is either the 5V Shanti powersupply or the USBridge Sig itself.
1.) What can be the reason for such a loss of data signal and course the white noise hiss.
2.) Could it be, that is starts to happen more, the longer (and warmer) the USBridge is running?
Please help - Thx.
Please help - Thx.
@cdgames: will Boss 2 be a network player or just a DAC? If the former, any indication of price?
You will need to use the Boss 2 on top of a raspberry Pi (I assumed that the 2 is similar to the Boss1) so the combo will be a Network player. You can use various software like Ropieee and others to use the combo as a streamer. Regarding price I do not know.
Antônio
Stated some time back on the Moode forum:
$99 including DAC, remote, and aluminium casing. RPI4 and psu sold separately
................ snip ......................
............................. snip ...................
I assume you've re-started your router at least once....
Based on your description << Running Audirvana on my MacBookPro and streaming wifi to my router >> can you exclude the Mac laptop (and Audirvana + QOBUZ) and experiment with a different set-up...?... like:
- router
- USBridge Sig + DAC
- music source from NAS or external USB storage
- LAN connection (and later on, WiFi connection)
It would be helpful if there is a new MoOde build and configuration for the alternative test described above. You may recourse to the services of a hairdryer for exploring a malfunction caused by excessive heat but BE CAREFUL and keep the hairdryer 1 metre away from the devices and use it with 'bursts' of hot air not longer than 30 seconds.
@cdsgames yes I did
Yes, I even used an other SD card to eliminate the SD card as source of failure
ndewm , did you try writing a new image to SD card of USbridge ?
- router
@CallMeMike
It is the same, when I use mconnect app and stream directly Qobuz to moOde per UPNP. This way MBP and Audirvana is eliminated as well.
I have a Lyngdorf TDAI 3400 on loan. This amp has build in streaming device and when using Audirvana/MBP with same network/cables etc, there is no issue at all.
- router
@CallMeMike
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
