Speaker protection with air coils and fuses
One question , 3Amp fuse with 56K ? no way it's nonsens to me ! 100 nF capacitor from output to ground without 10 ohms serial resistors, an other mistake ..... sorry poor design.🙄 maybe attached one it's better .
The back panel shows the typical reset button of a (thermal?/bimetallic?) circuit breaker, the PCB shows a conventional crossover network, no protection circuits or elements (fuses, thermistors, varistors) visible.
There is "something" between both which may solve the mystery.
JM
The photo corresponds to the same piece, photographed from the inside (by me) and from the outside (I found it on the web, it saved me the work).
The very simple (2-way) Xover and protection circuit are mounted on that PCB only.
The red button that resets the circuit penetrates inside one of the coils.
I have no idea what to call that piece.
Mystery solved, turk 182 is right, and it is the same size as the photo. Good memory ! 😉
Thermal circuit breaker .... calculated to cut when a predetermined current passes through it, simple and effective.
