Acoustic Horn Design – The Easy Way (Ath4)
Thinking about the "LWDI" a little more, one wouldn't want to go too much far off-axis because even a highly directional device could have this average DI pretty flat after all. So I should probably take something closer to the axis. When this is flat (or close to the target), the rest should be no worse, hopefully.
That data is definitely normalized. Here's some non-normalized data for a different device driven by a constant acceleration source:
attachment.php
attachment.php
I don't know how one defines "cutoff" for this kind of device, but the predicted SPL starts to drop significantly below 500Hz. The radiation impedance at 500Hz is very low at 0.027+0.229j.
What can be said about the system above comparing a tone produced at 500 Hz or 4,5kHz? It has the same acoustical output more or less the same DI... But impedance differs a lot nut I doubt that can be the only difference?
This simulation, like virtually all presented in this thread so far, uses an ideal constant acceleration element at the throat boundary as a source, i.e. is in fact ignoring the real loading properties of the device (at least as I understand the matter). I'm not sure how meaningful this is in that regard.
- As long as we are interested in radiation patterns only, this is perfectly fine because the pattern is invariant, but for the "loading" aspects, I would think we should use a driver model as well. Shouldn't we?
That's true. The averaging window may have to be tailored based on the target beamwidth.
What I meant is that even a highly beaming device (i.e. one with steeply rising on-axis DI) will have more or less flat DI at some angle off-axis.
- In reality even the so called "flat DI" device will have the DI flat only in some off-axis angle range.
This simulation, like virtually all presented in this thread so far, uses an ideal constant acceleration element at the throat boundary as a source...
Absolutely.
My first reaction was similar to this
Makes my point even more than I expected.
More than I expected too, I started to wonder what the mechanism could be- how could the response only drop substantially so far below the frequency that the load drops off?
I arrived at similar doubts to you because I still can't see it.
So if a proper driver simulation is done and confirms the result then there will be no reasonable doubt and I (and others) will have to rethink.
And that will be at least as educational as the opposite result.
Best wishes
David
Why not use constant velocity (p=v*z) ?! I always use in my simulations constant velocity and I have not observed any phenomena related to radiation below "cut-off" frequency.
The picture below demonstrates SPL at 1.3m and radiation impedance of the biradial horn (designed by well known Japan corporation) that I simulate in ABEC3 under constant velocity condition. Radiation below the "cut-off" falls drastically.
