How stable should DC anode voltages really be?
No....I can't be bothered to prove what I have found in RL....but it is readily available.
Fluke 28II
Fluke 187
Input Z is far lower on 200mV AC range (or is it DC ranges?), than the 2V or 20V range, for example
That is incorrect. Here is the spec for one of the meters you cited. You will note that the input impedance is the same10Mohm on all mV and V ranges.
I suggest you SHOULD bother looking up this info before you post incorrect statements.
So what would you suggest causes the phenomena,
Oh internet troll king?
(Check the DC specs)
P.S.
Data sheets are renowned for "stretching the truth"
Quoted from a number of calibration engineers....
(Yokogawa are about the only instruments, that I have spent time checking, which actually meet their data sheet accuracy; albeit with some complex mathematical caveats, clearly stated in the measurement conditions)
Funnily though,
The data sheet that came with mine, was a great deal more complex than that single sheet of blurb
Perhaps then, my 187 has a fault?
Key sight calibrated and yet...faulty?
I mean...
Think about it....
10 MegOhm AC input impedance... across ALL frequencies in its capability of measurement?
Hmm. Ok...
Precisely...at 50 or 60Hz only.
Most interesting, is that you chose the obsolete 187 data sheet to quote, and not the 28II, which has frequency response and everything.
Mahooosive caveat
At 1kHz? What you think it is then? When measuring HT ripple/perturbation, in an amplifier, at maximum outputs with a stiff supply, requiring the use of mV scale?
Grow up, go talk like **** to someone, who doesnt know what they speak of.
Sorry for the digression. My point is that I agree with astouffer. The input Z of the DMM is not causing loading. And even if it was, a steady state additional load would not cause the voltage to fluctuate.
I was suggesting that poking around with DMM leads can cause momentary disturbances to a high Z circuit. Stray EM coupling, ESD and whatnot. And it's hard to predict how a digital display would react to those transients. This is why I suggest connecting a scope probe solidly and posting the trace so we can see what the fluctuation looks like. And preferably with the input shorted.
Oh, and read note 4. on that schematic.
No excuse needed as topic starter asks open questions without showing us an actual circuit. Same goes for a high voltage supply where B+ can be defined as existing before any regulator. Some more text explaining the situation is appropriate.
It is not unusual that a DMM changes the load to a circuit because of the extra capacitance and inductance involved, leading to changing operating conditions. If I stick the probe of my Fluke to a grid of a high amplifying stage this gives an audible signal of circa 0,5Hz. Checking anode voltage of a phase inverter with this Fluke one downloads the circuit, resulting in changing read outs. Not uncommon at all.
so since the voltage ultimately stabilises over a period to a final voltage with the meter on but quickly returns to the slow oscillation as soon as the meter is taken off and reconnected (disturbed again) then this is really a meter created issue and not some core instability in the circuit?
Reactions: chiily
If the main b+ voltage isn't changing but the anode voltage is, that means the tube is changing how much current it draws.
Until you get some test equipment its all speculation. Download a frequency meter app for your phone and tell is what frequency the hum is.
If you put you meter on AC and read the main b+ what does it say?
tonescout,
Often:
The AC bouncing is caused by Power Mains Line Bounce (different loads turning on and off at your house, and neighboring houses . . . water heater, electric heating, toaster, dryer, etc., and even further up the Power company's customers (closer to the original Dynamos that produce your power).
Try doing an AC reading of your power mains, does it bounce from reading to reading?
But often, power line bounce has shorter transient times than the time of a single DMM AC reading, so that test may, or may not work.
Line bounce is not Hum.
There are many causes of 50 Hz hum in the speakers.
