If they use a soundboard as a passive radiator, like in a piano, the size should be similar if you want any low end level. Those speakers are too small. Try a bass guitar without an amp to acoustically amplify the fundamental. Hear any 50hz?
Just lost all respect for that company. Not one measurement and then this:
ACCESSORY 2: BRODMANN LOUDSPEAKER CABLES
Brodmann loudspeaker cables were developed in nuclear physics laboratories in the USA.
They significantly augment the effects of the Acoustic Active Principle. These cables
feature a number of exceptional qualities and are also used by NASA.
And then they go on with more ridiculous cable snake oil.
Reminds of these, which I listened to. Totally unimpressed at any price, never mind >$200k.
Model D | Steinway Lyngdorf | The World's finest audio systems
What next, speakers from Gibson?
Hi i would like to thank you All very much for the very valuable advice. Your statements confirm my feelings.
Speaking of enclosure design and construction i think that looking at the very best products in the subwoofer market will tell a lot indeed. I know i am trivial now .. but the range below 150Hz is the more critical for enclosure vibrations control and damping
Personally i would segregate the woofer in a separate cabinet very well designed and build. I do not like tower speakers for this. I prefer a subs + satellites solution with the satellites mechanically decoupled from the woofer cabinet. Like Wilson Audio for instance. The bass cabinet is a great technical challenge for me.
Aren´t you exaggerating ... well .... a little?
If it only were SO easy to polish a turd?
Hi ! yes of course 😱 i am slightly bipolar 🙁
But really is in the bass the speakers differentiate more. These days with smaller rooms people are more used to mini speakers that have nothing below 100 Hz at certain spl ... they do not know what a real bass is.
I did not know before listening to a big pair of JBLs monitors.
One very popular speaker is the Kef ls50 ... they have no bass to speak of.
Usually they are tested with voices ... just play a pipe organ track on them and listen for the distortion.
A friend of mine has a pair of speakers with a 5" woofer ... he put on a track full of bass and higher spl than normal and the woofers bottomed out ... he had an earth attack ... they are quite expensive but repairable anyway
He had to replace both woofers.
Concrete is good too!
i think that there is nothing more dead sonically than lead ... just try hammering a lead slab ... just a very deaf sound
But lead is not stiff ... so a sandwich of metal and lead in between could be the best
There is an easy way to check for cabinet resonance .. using one of this placed on the speaker cabinet
the stronger the resonance the stronger the sound from the mechanism ...
a musical instrument will amplify the sound of the mechanism ... a speaker should not amplify it at all
So musical instrument and a speaker must have completely different properties
Bosendorfer is a piano and grand piano instrument maker, so maybe you're misunderstanding the quote?
Hi my understanding is that the design/build a speaker like it were a musical instrument
This is a completely wrong approach
Like designing an hammer like a knife
hold the phone the OP needs to provide the source so that the quote is in context...and a quick googling seems to put Bosendorfer in the same position as Yamaha, a company that produces musical instruments as well as loudspeakers??
Hi ! i found here
bosendorfer speaker phylosophy - Google Search
anyway i remember very well a review mentioning that phylosophy ... [/QUOTE]
hold the phone the OP needs to provide the source so that the quote is in context...and a quick googling seems to put Bosendorfer in the same position as Yamaha, a company that produces musical instruments as well as loudspeakers ?? ...
Yamaha has never said what Bosendorfer said. They do produce both ... but i am sure they follow completely different design approach. I am 100% sure of that. Just look at the drivers ... Yamaha drivers are out of this world.
Bosendorfer use off the shelf drivers ... hardly high end. Very wrong comparison i am afraid.
A box is not a musical instrument?
Cajon - Wikipedia
Yeas of course ... a speaker box is not a musical instrument.
A pity, what was the reason?
Bosendorfer's theory of "controlled" internal resonant plates is a complete contradiction to that of "dead" cabinets. It really seems that the latter is only desirable for low frequencies. ...
About the difference between a speaker and a musical instrument
One makes music and the other reproduces music.
wouldn't that be an axe?Like designing an hammer like a knife
as to whether or not the enclosure should or shouldn't radiate would depend on the end result,no?
Hi yes ! that was my point. Complete different function. I would go even further ... i would apply some principle of speaker design also to mic ... a mic is just a speaker used reversed. The design and the construction of the mic body is very important to tame any resonance. Only the diaphragm must respond to the air/sound waves ... It will sound better with a non resonant body.One makes music and the other reproduces music.
Maybe a composite material dense ... like panzerholz and similar ?
In a mic any slight resonance will be hugely amplified by the chain downstream ... they are very sensitive devices. The good ones i mean
... "Bosendorf doesn't avoid internal resonances, it uses them for a better sound."..
and then you look at the drivers they use and everything is clear 🙁
Unfortunately very toxic ... very But the test was very telling... Lead sheet is a lot cheaper
The vibes are a problem only from 150Hz down ... i would like to measure the distortion at 100dB below 150Hz of the bosendorfer ... if they do not fall apart of course
A purely passive speaker would probably do well to avoid any sort of cabinet vibration, as this could lead to things such as distortion.
If you however have an active cross-over with a DSP configured to cancel or reduce any cabinet-induced distortions, well maybe it could work...
But in any case I'm quite skeptical that it could provide any benefit at all over a totally stiff and unmoving cabinet.
- Member Areas
- The Lounge
- About the difference between a speaker and a musical instrument
