I've had the 2145, no lift 1-4khz, nice boost in highs, just needs bass boost to sound balanced.
But the fa22 looks nice too, needing the passive eq ckt though. And no phase plug, eventhough the cylinder in the 2145 seems too short.
What do you think ?
What do you think ?
I can't comment on the TB, but for the SEAS a few things to note. I have a pair. If you want bass, it will need a huge cabinet, much bigger than most 8". I think it was about 3 cut ft. You can look it up in the application note. It also requires a super tweeter if you wanted real treble.
Oon
Oon
some years ago, Ken Lehman made a K-coupler for a Meniscus Eclipse polycone 8. It had a curved reflector and round duct port above the woofer. At the top of the front chamber was a removable panel which allowed a smoothing stub to be added. Left alone, response was somewhat rough. When the stub was added, response smoothed, impulse response improved, and "artifacts" disappeared. That or simplified would probably play with the low Fs SEAS. Now whether these speakers have enough treble power to work = ? W8-1772 played nice treble wise in all of my Karlson toys.
Oon's report on the SEAS sounds like it could use augmentation. BetsyK needed that in a Karlson K12 but otherwise really loaded well.
I would just highlight that to me, it doesn't sound like a "real" tweeter, something in a 2 way build. But if you are happy with it, you don't really need it. YMMV of course.some years ago, Ken Lehman made a K-coupler for a Meniscus Eclipse polycone 8. It had a curved reflector and round duct port above the woofer. At the top of the front chamber was a removable panel which allowed a smoothing stub to be added. Left alone, response was somewhat rough. When the stub was added, response smoothed, impulse response improved, and "artifacts" disappeared. That or simplified would probably play with the low Fs SEAS. Now whether these speakers have enough treble power to work = ? W8-1772 played nice treble wise in all of my Karlson toys.
Oon
3ft3 is fine.
12" deep x 19" wide x 31" tall = 3ft3 assuming 3/4" wood.
If you made fern & roby raven's speaker stand part of a solid box, dimensions are very similar.
If you pop by SEAS main webpage you can download the application note for it. That gives you the cabinet size and RC network required.
Oon
Oon
Fa22rcz
.707 sealed
Vb = 1.54ft3
F3 = fsb = 60hz
Ported
Vb = 2.93 ft3
F3 = 36hz
Tune = 34hz
W8-2145
.707 sealed
Vb = 1.5 ft3
F3 = fsb = 64hz
Ported
Vb = 3.18ft3
F3 = 35hz
Tune = 36.6hz
Speaker Box Enclosure Designer / Calculator
Basically very similar sized sealed and ported with similar f3's
.707 sealed
Vb = 1.54ft3
F3 = fsb = 60hz
Ported
Vb = 2.93 ft3
F3 = 36hz
Tune = 34hz
W8-2145
.707 sealed
Vb = 1.5 ft3
F3 = fsb = 64hz
Ported
Vb = 3.18ft3
F3 = 35hz
Tune = 36.6hz
Lots of views, that’s good.
After watching another Steven Gutenberg video blog, he’s mentioned it before, if you listen to a wide variety of music, you may need multiple speakers.
I really think he is right.
Even now, my jbl’s in my avatar kick butt. I listen to stained or the weekend at higher volumes. But I also want super clean intelligibility, think Allison Kraus, the cd that has whisky lullaby on it, I swear she is mumbling on some of those songs, maybe humming more than signing anyway......
I’ve had luck with a 4 x fe87 short array, not for music (ew), but awesome intelligibility for late night movie listening.
8” full range Run wide open is a good niche, I think it can work, especially for yo-yo ma, voice stuff, so and so and his quartet, etc.
I would tend for the TB, that Seas i heared it and the higher part of the frequencyspectrum is very resonant and ear-fatiguing i think. It's also almost double as expensive as the TB and for me not worth it. You also see that on the spec sheet. For the rest they are very similar on specs.
A 3.2cuft ported cabinet gives me a F3 response (in winisd) of 33.6Hz for the TB. That is with a 4" vent of 5" 1/3th long and a max port air velocity of 14.5 (wich is below what is needed). It's also good one for an (ML)TL or a TQWT with these specs, the Seas much less.
Thanks for the port dimensions.
Tang band retails here under $100 with free shipping and maybe 7% sales tax.
Seas comes in at $150, plus sales tax and shipping.
Any idea on the tb's seemingly too short cylinder phase plug ?
I remember steve deckert (decware) did a paper on a similar but scouped out phase plug.
DECWARE - Audio Paper - Decware Phase Guide
I'm not an expert on phase plugs, so i can't tell. But i know it's not an issue from hearing it. Someone with more knowledge can probally explain why.
just filling in the void (cavity) which would be under a dust cap helps so imo a short plug with a flat end is OK. I dread the proliferation/fad of car speakers and whatever which have "bullet" plugs as have a cheap Boss 10" with one. It was around 20 bucks and would have been about as good as a Nirvana other than a plastic ring at the end of the former causing some funky stuff.
The SEAS sounds warmer than the TB. The TB is faster with better transient response and sounds more agile and open but also dry and more analytical with the tendency to get nasal with some records like Fleetwood Mac Rumours. The SEAS has more creamy mids and fuller upper bass.
is that Tangband more mellow than their 1772?
High Aspect Karlson coupler with Tangband W8-1772 - Saxophone - YouTube
Well, it has less climb (weaker magnet), and the 2145 has a nice lift past say 4.5khz, where i add boost anyway. To me, add some bass boost, and freq response has the shape i like.
The 1772 is brighter, not mellower, and only fit for backloaded horns. And i don't like it. If you want an other of the TB 8" fullrange drivers better look at the 1808 that is slightly better, but a lot more expensive.
On the 1772, bob brines, including baffle step, used about 8db of "fixing".
Larryspkr uses 8db baffle step in his mltl as well.
Tang Band W8-1772 Impressions.
I believe fern & roby's "Raven" (using an exotic f22) uses a 2" port, not sure where they tune.
Given that the port is a little of a break compared to a subwoofer's air blasting out the port, could someone compute 3.2ft3 tuned to around 35hz for a 2" port ? or even 40hz also ?
I have both of these drivers, had them in various cabinets and tried really hard to make them sound good. The W8-1772 blows them away on every level.
Larry
Larry
- Full Range
- Seas fa22rcz vs. Tb w8-2145
