your mltl with 4mH and 10ohms baffle step ?
what are the outer dimensions of it ?
"I don't have a drawing but the inside dims are 10X10X44 inches, driver is 10 inches down from inside top. Port is 4 inch diameter, 2 inch long centered 5 inches up from inside bottom. Filter is a simple BSC with a coil paralleled with a resister in series with the driver."
I wonder if the stronger magnet does a better job of controlling the driver...………….
1772 ain't cheap, and I didn't care for the 1-4khz region in the 1808
Still have them, sitting on a shelf right now. I have 4 2145"s not sure what to do with them. The fa22's are going up for sale.
Larry
Larry
Huh. I liked the 2145, but havn't directly compared it to a 1772.
Would be tough, needing side by side with eq for a fair test.
Maybe you all like the 1772's dispersion...………..
got 2 more.
going to try the cobra 2 filter
1mH + 4.7uF + 3.9ohm (someone else had 5.6 I think) = 2,300hz
