The frequency dependence of infinite baffle-ism
This is how I think about 4pi vs 2pi (baffle step)
When wavefront reaches the edge of baffle, it starts to bend over and spread wider around in space (remember this is 3-dimensional), then same energy (spl, amplitude) gets spread into larger space and pressure diminishes.
Diffractions secondary wavefront(s) make minor disturbances locally, ie. variations in pressure with different summation at various deviation angles.
Some food for the thought experiment. Acoustic radiation impedance.
The sphere is R200mm, driver is R30mm, and is an ideal membrane under constant force (acceleration).
Up next, a map of radiation impedance from the driver around the sphere. Might take a day.
What makes you so certain, do you find it inconceivable that they (wavelets) exist?
You might as well ask why Huygens' wavelets don't go backwards!
If the physics seems contrived, it's because it is contrived. If you want to 'make believe' there are secondary wavelets, then you also have to believe they are inhomogeneous.
If you do, you get an extremely powerful technique that works well whether it's 'true' or not.
On that latter point, I think we both agree! 😎
In that case, the technique would not work!
If each wavelet radiated equally in all directions then, in addition to propagating a forward wave, the wavelets would also propagate a backward wave which would travel towards the source.
No such wave is observed, thus the pragmatic need to invoke inhomogeneity.
As you pointed out, problems like that are raised in the wiki page I linked to earlier.
The physics of diffraction is more extended when it comes to light.
However, we don't have a particle theory of sound - although I recall writing in this forum about a recent article to that effect.
I must try to dig it out again - or maybe not! 🙂
