No-global-loop amplification
Please Jeff can you check if it is the right orientation for the thermal sensors?
No, according to TC74AO pdf data, this will be the right way.
Hi Thimios,
Your version of the temp sensor is a bit different from the one I used, but as far as I remember, in all the versions the sensor part is placed under the board, so that the screw goes through both of them (a plastic spacer is used in between).
See the fragment of my build.
Valery
21" century protection.
Picture n1 serial scan.
n2 main software Leaded!
I have one question only now.
Led is on even when amplifier-protection is off.
Led is on but with a little higher luminosity when system is on, is it right?
Something doesn't sound right there! What happens if you remove R22 completely? What do you have installed for R21?
J8 pin1 = GND
pin 2 = power on switch (ground to turn on)
pin 3 = GND
pin 4 = Audiolab remote trigger (ground to turn on)
pin 5 = 12V trigger + input
pin 6 = 12V trigger - input
