Interested of course.
Question:is it possible to connect directly to the balanced input of the TPA3255? I can do that in my TPA3255EVM and it sound beautiful. Just missing PFFB as it is right now.
In new version PCBQuestion:is it possible to connect directly to the balanced input of the TPA3255?
This amp no have pumpingDo you phase reverse one of the channels to mitigate power pumping?
OK - but maybe you should try - its still a relive for the PSU. Anyone can try it - just reverse polarity for in and out on one channel...
drM- I'd especially like ur amp optimized w/ OPA1656 opamps. But they'd have to be soldered on- correct?
In speaker crossovers, one are always advised to mount all inductors ortogonal to each other i.e. in a x, y and z direction. Is there also here a problem with cross induction interference? If so, it might not be soeasy to solve.. It would need a small board mounted upward... and there are 4 of them :-/
TPA3255EVM has them all parallel and in close proximity to each other. I've read through a few of TI's documents and have not seen any comments about this... a lot of other designs have this as well.In speaker crossovers, one are always advised to mount all inductors ortogonal to each other i.e. in a x, y and z direction. Is there also here a problem with cross induction interference? If so, it might not be soeasy to solve.. It would need a small board mounted upward... and there are 4 of them :-/
Rename one set of A, B, C and D so no chance for mixup?
I would ask for this as well drM. I had to PM to ask which was L or R +/- on a 2.0 setup and it’s also different for a 2.1 setup. Maybe printed on bottom of board?
Thanks,
Pete
Are those grounded mounting holes? IMO would be better if they were electrically isolated so that a ground loop breaker circuit could be used with less hassle.Version 3
Can have a separate tab for grounding
about inductors, they do not have an external magnetic field, until saturation, the maximum current is -15 amperes
- Group Buys
- Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
