Simplistic MosFET HV Shunt Regs
diyAudio Chief Moderator
Joined 2002
Só it's normal these differences between the double triodes of the same tube?
Yes, you may even see measured and matched tube pairs on offer with still different enough gm & Ip noted for each section.
Joined 2002
Salas will be nice to know the voltages in each position to know when is faulty, and better in the schematic (if you don't have time let me know & I do it for you and post here so you can move later to the 1st post).
It should be showing this kind of rough voltage points for a 350V input 300V output classic example. See if your example follows the voltage distances.
