No-global-loop amplification
Hi Valery, apologize 🙂
A bad gnd connection on second probe give the problem!
Here is again.
First picture Tp1.
Second picture Tp2.
OK, cool - it's better to measure at TP2 - same shape but higher amplitude - less noise. Very good in terms of phase alignment.
It looks like you didn't reach the minimum - if the trimmer is at its limit - amend the value of the resistor that is in series with it.
The green one will go down to some 100mV RMS and become somewhat corrupted - then that's a pure error signal.
Hi Valery, how critical is the C18= 27pf?
I found a ceramic 27pf common type and a 33pf NPO.
This will be just for test, then i will order the right type.
The same for C11=10pf.I found a ceramic 10pf NPO.
I'm in a hurry to listen the Simpelstark in stereo mode.😎
