I can see how it would effect/change the sound.
I should build them into 4'X8' sheets 🙂
BIG baffles...
BIG baffles...
Yes, keep in mind that the speakers expect some pressure feedback around the edges. if you make big "wings" you would have to compensate with crossover changes to maintain the balance.
Sheldon
Sheldon
I have the worst comic presentation...
No, I wouldn't mount them in boards, and if I weren't single, I suspect WAF would negate that option even if I wanted to 🙂
Think I'm going to build some "temporary" spider legs for them out of ply so I can make a template for the proper ones. Researching hardwoods for that. As they will be painted, I'm only worried about the hardness of the wood. Not sure I want to go too crazy as it will very much complicate the cutting/finishing of the legs.
And I'm curious how a class D amp will match up with these?
From what I understand, they handle low impedance loads well?
Make sure you have the protection boards installed , especially if you are going to be using big amps to drive these
David
David
This is very good advise. The treble panels are reliable to everything except too much power.
Sheldon
- Planars & Exotics
- ESL 57 with Marantz 1030???
