EL152 socket
Are these sockets similar in style to regular octal sockets?
In the same way compactron are similar? EDIT: they're the same
They may utilise 10 pins, but look very much like they fit 12 pin sockets on an octal diameter.
Look for octal and 12 pin relay bases (usually they are rated for 250V however)
Hello, I have two of this sockets. What do you need?
Andreas
I purchased a pair of Chinese sockets, but quality is poor as you know. I was looking for the socket drawing with measures so I can reuse for building sockets custom-made.
Worst case scenario I can build the drawing after measuring the valve, but is work I want to avoid if possible as am struggling with free time
thanks
Ale
Yes, I've been thinking of them, too. They had been designed by Gerd Reinhöfer himself, founder of this company, who sadly passed in 2013 at the age of only 51. Prices may appear to be on the higher side, but consider that these sockets are made mainly from teflon (with a phenolic base plate) and the pin contacts are replaceble, if needed.
Best regards!
