Yep, the 18Sound 6ND430 is an excellent driver. I have a pair in some compact PA speakers and they sound great even when they're receiving very high power levels.
Chris
Chris
Seems like a great driver also for high power midrange!
Maybe look at the Eighteen Sound 6ND430. I use it active at 400hz and passive at 2200.
Many different and Good options
Beyma reccomend to use TPL 200 from 1000hz
Im trying it right now from 1200 and it gives great clarity to the female voices.
I give it just a Little bit of eq
Dropbox - IMG_20200928_205924.jpg - Simplify your life
Only use EQ to subtract, golden rule 😉
Are this because you missing a driver? so the x-over have a gap?
Dropbox - beyma tpl200.JPG - Simplify your life
I am trying to compensate for the frequency response which is weaker from 1000hz 🙂
I think it is over 10 db difference from 1000 - 2000hz but i do it gently becauce i like to dampen it a little bit up to 2000 or 3000 anyway
Got it
Seems better now☺️
Seems better now☺️
Had the chance to try a Crystal clear and Beautiful looking driver.
Now it's in a plastic cup filled with insulation.
I Will try it for a week, it's been plugged in for half an hour and i will spend the evening adjusting the dbx.
The characteristic is not the softest as expected but the detail it provides along with the amt is very pleasent.
If i would choose this driver i would probably use 4 of them.
VISATION TI 100
Dropbox - IMG_20200930_170840.jpg - Simplify your life
VISATION TI 100
I spent a lot of time trying to integrate the new driver.
I have a really Hard time to make it sound like i want to.
I need to do a very Hard EQ on it in order to give the sound some weight and warmer character.
Dropbox - IMG_20201001_233701.jpg - Simplify your life
Still a Little shouty
Why is this?
The box?
It's very clear and really a great higher midrange as it plays right now.
Why is this?
The box?
IF it's the TI 100.. non-linear distortion jumps above 1 kHz. Pressure also increases a bit above 1.4 kHz on an infinite baffle.
Two nasty ridges above 5 kHz that are about 10 db in pressure above the average..
Basically a very good midrange with a steep low-pass near 1.5 kHz.
Still, not what I would call a "warm" driver in sound when eq.ed flat and compared to others eq.ed flat..
This sound you got, is this with high pass filter on ?I spent a lot of time trying to integrate the new driver.
Dropbox - IMG_20201002_065021.jpg - Simplify your life
I think the visaton sounds great in the higher midrange
Scott: i have only a pair of plastic cups for baffle, do you think it can be s problem?
Viper: trying it to 3000hz now crossover
Hartono: yes hig pass and low pass.
Still waiting for accoustic elegance speakers.
Now you adviced me not to cross them over 300hz due to baffle step.
Still a bad idea to cross it higher and just correct the step with EQ?
Maybe it would be a way to give the midrange some weight and warmer character?
If i go for the flexunits maybe i Will experience a thin sound also and start to EQ it like crazy?
One option is of course to make it a four way and add something where this 4" is lacking
I think it's a nice sound in the higher frequencies.
What would be a Good lower midrange?
Something that provides some pressure?
Pa 8" ?
ALU 8"?
Pa 8" ?
ALU 8"?
Try set the mid and twe in line on the edge for full timing, remove the eq for the mids & flip to 12db LR, rev pol on both mid's in the filter, and then set the levels on the amps when listening. 24 & 48db have som hard "ringing".
Should do the job.
And yes the box may lack some bass.
Should do the job.
The reason i cut so steep was to avoid overlap because i was afraid IF there was phase issues they would get worse on 12db.
Need to look more into this ☺️
It's a good point. If you have a mic you can do a "time alignment" in the dcx2496 pdf. The phase will be 100%. It's free and powerful.
If you use an active crossover you can use a Linkwitz-Reilly filter which is in phase across the frequency spectrum.
- Help to choose the ultimate midrange driver
