The ACP+ and ground plane are both now available for purchase in the store.
This is great news, awaiting pics.
HI, do you have a proven version ?
maybe a balanced version ?
thanks
i need a balanced gain stage for this output stage :
https://circlotron.audio/sites/default/files/2020-09/RADIUS_2020.png
I would like replace the opamp gain stage
best regards
Sébastien
thanks
best regards
Sébastien
Do you have any pictures of the ground plane?
Pictures will be up in a few days.
Will the ACP+ drive a MOFO?
Yes, i like it
I believe I read that the store boards were the same format as the BAF boards. If that’s the case, will there be a corresponding chassis available? They appeared to be made with a certain configuration in mind.
The original BAF boards with the ground plane were designed to be chassis free. I did place one in a chassis I found online.
- Amp Camp Pre+Headphone Amp - ACP+
