My KISS LM317/LM337 Regulator
Joined 2002
After looking around the forums and copying a few good ideas I'm taking my first shot at PS design so be nice! My goal here is to build a very basic +/-12 supply capable of delivering 100ma or more and fit on a smallish PCB. I realize the sky is the limit in regulator design but I'm trying to master the basics here and build on that later. The only suggestions I'm pondering right now, but I'm open to others, is whether I need to keep C5 and C6 and where to find some 'high ESR' electrolytics for C9 and C10?
Dan
attachment.php
I'm going to deem my final schematic as a good basic 'datasheet' regulator. I've followed the basic guidelines of the datasheet plus a couple of twists. This will get me started and I can't wait to put my scope on it and perhaps then pursue some 'upgrades'.
Dan
attachment.php
Looks alright. With a decent layout, these should serve you well.
Why this much LED current though? Those are going to be fairly bright, possibly more so than you want for what I assume are "yep, this voltage works" indicators. You might have needed 20 mA 40 years ago, but things have gotten a hair more efficient since then.
C5 & C6 not needed if reg within a few cm of the 1000uF.
C9 & C10, you can add series R to compensate for low ESR.
If you have separate transformer secondaries you can make two identical LM317 regs and wire them in series.
It was a great 'starter' project for me. In the future it will be the foundation for some of the great ideas available in this forum.
Dan
Yupp --the ESR of the filter capacitor is important -- a low ESR value is NOT recommended with the LM317 as it may cause instability. Over 100 milliOhms please.
