B1 with Korg Triode
Hey there, I am having mixed results with the Meanwell PSU, it seems to randomly start oscillating and radiating really nasty RF, which gets picked up by various other components in the chain. I have a krell preamp, which is particularly susceptible. anyone else having problems with those little Meanwell powersupplies?
Is it a long high pitch ringing?
Try a different amp.
Mine was working just fine but has started buzzing, or humming.
Which is great as it is forcing me to seek an alternative so I've signed up for the SSLV1.3 UltraBiB group buy and have scored a nice fat Toroidy donut in preparation for what will be my second ever DiY build.
@Hadox, I signed up for that too, seems like an elegant solution.....
@AnthonyA, it is not really a ringing, I get that if I tap the Nutube, applying some bitumen damping resolved that. It is a RF ringing, similar to using a cellphone near a radio. Once I reset the PSU it goes away for a while and reappears usually after a few hours. That being said, it hasn't done it in the last two days.
@Mark Johnson, that is awesome, thank you. This should probably be a group buy....
Just out of curiosity, the heater voltage seems to be developed seconds after the plate voltage is developed during power on (due to the 270 ohm/1000 uF before the zener). Will there be any degradation in the nutube during this time? In real tube amps, sometimes a delay circuit is put in so that the filaments are heated up before HV is switched on to preserve the life of the tubes. Does it mean it is best to leave the nutube on all the time once it is powered up?
