thanks i build circuit but there is a problem
without input signal and no speaker connected and no heatsink and just +/-45v supply i adjust 0.33ohm resistor voltage about 10mv but it begin rising continuously and go over 20mv and 2sc5200/2sa1943 become warm and if i didn't disconnet psu become hot.
is that normal or something is wrong in circuit?
i get same problem its not normal u need heatsink on it. put heatsink and be sure bd139 connected good on it. heat changind voltage. mine was changing the bias voltage too i was just lucky trying to check heat on transistors and i see when i push bd139 on the heatsink voltage stop changing. and then i check the transistor and see bd139 not touching good on heatsink. sorry for bad english.
thank you that helped me alot
Hi friends. Can anyone help me about the transistors shown below are original or not?
Apparently they are... but in this days we never now...
I made this amplifier for test my home DIY speakers (two way TL).
D4 on component layout wrong polarity, in post #253 is corect componenet layout.
i have 2 question:
1-can i remove C13 and connect SGND directly to PSU ground?
2-can i put a 10K resistor beetwen IN and SGND?for better noise reduction specially when no input connected.
Can any one have 200 to 250 watt in 8 ohm AX-14 amp pcb
Hello
I want more power in ax-14 amp. can i just add more pair off op transistor, I don't want any changes in sonic quality of amp. Please help if someone have more power versions of this amp.
Hello
Oh!, i forgot to explicitly mention that pcbs are free. only shipping and handling of INR 200. within India only.
Hello prasi
I want that pcb, how to contact you I am from amravati Maharashtra
my email - Sanbadgujar@gmail.com please contact me
Hello
at page 393 (#3929) alex mm make 2 pairs ax14.
mr. mile wrote before "rail voltage +/-45V for single pair or +/-55V for two pairs, +/-65V 3 pairs, +/-75V 4 pairs, +/-85V 5 pairs and +/-95V 6 pairs or more". but i dont know if you need to change some thing or not. you have to read....
good luck...
good luck...
Thanks karachay
Have you build Ax-14 with more than 1 pair
Thanks karachay
AX 14 with two pars.
Hello kandimba
Thanks for pcb layout
Can you build it how it's sounded. because I have 42 -0-42 Ac 700VA transformar ,is it ok to get 150 watt on 8 ohm load.
Well, 42-0-42 VAC it means 58-0-58 VDC. I think that you gona get something like 130 W in 8R.
my psu's voltage is +/-47 volts
i looking for mje340/mje350 equivalent.
please tel some transistor part number to replacment.
is bd139/bd140 good or not?
what about 2sc4793/2sa1837
Mix of smt and through-hole components, interesting layout.
Any chance for a full link? Or full layout design?
Thanks.
Thanks.
Hello kandimba
Can you have any good tone controlar for this amp.
Which protect ckt you use for DC protect, spekar protect, short ckt protect please spcify
Thanks.
I ordered the production of PCB here:
Apex AX-14 - Share Project - PCBWay
Hello kandimba
Hello Sanbadgujar, sorry but this is only that I have.
Hello kandimba
try apex ml3 for tone control. for protection for ax14 i used apex f100 psu. it have all you need.
- 100W Ultimate Fidelity Amplifier
