Acoustic Horn Design – The Easy Way (Ath4)
According to Vance Dickason:
"The solid black curve represents the Radian 951PB mounted on the B&C ME90 horn and the dashed blue curve represents the compression driver without the horn. With a 5.02 Ω DCR (Re), the minimum impedance of the 951PB/ ME90 was 5.4 Ω and at 2.5 kHz."
There's another practical implementation (courtesy of misog) -
(The raw waveguide measured with 4 ms window. I believe the driver is 18Sound NSD1095N and the woofers are 10".)
866517d1596874822-acoustic-horn-design-easy-ath4-4ms-jpg
If this is indeed the NSD1095N, the extension in the top octave is rather disappointing for such an expensive 1" driver.
Even when taking the waveguide into consideration.
In fact, it's worse than some drivers with 2.5 and 3" diaphragms.
OTOH, it's pretty smooth and should sound nice after equalization.
Do we have a list of comp drivers with naked phase plug at throat suitable for ATH waveguides?
'We' might start another thread - if possible with a sticky first page that includes the list.
Here's a proper initial candidate.
While the phase plug doesn't quite end at the exit, its 31° angle should suffice.
This is what I meant when I said "acoustic impedance". The question was about the influence of a negative throat angle -
These are two ~10" OS waveguides, 36 mm throat. All that is different is the throat angle: 0 and -6.5 degrees:
attachment.php
I have no thoughts on that yet.
- If anyone wanted to study such devices as the one shown below, simply use the guiding curve and the morph feature - it occurrred to me today how easy it is with Ath, with all the niceties of the tool availabe. The initial cross-sectional shape is given by a superformula here and it is morpherd to a rectangle, starting at about half of the length.
