transformer VA rating
hi everyone,
what is the purpose of increasing the transformer VA or capacitor farad when the output is limited.
can this help in improving sound or whatsoever?
increase the trafo va and capacitor value, which 1 is more reliable and worth it.
Higher VA
Better regulation (less voltage sag under load)
Less radiated heat
More Capacitors for better powersupply smoothing (less ripple voltage)
Lower Output impedance
Lower Output impedance at low frequencies eg 20Hz
Both is good.
I feel loading a transformer at 1/3 it's rating or lower is nice, at 1/2 rating it starts getting quite warm, above half rating is not generally recommended at all. We're fighting a battle of the heat wars. The less radiated heat inside your chassis the better.
This is just for one channel on my 50w Single-Ended BAF2015 Schade Enabled amp!
attachment.php
