Bigbottle Phonostage Builders thread
You may have a similar issue to one I've had with the actual heater voltage needed. Mine has been modified for 7V heaters by changing the 2.7V zener to a 2V.
Also change the two 8.2 ohm resistors to 4.7 ohms or you could add a 5.6 ohm resistor parallel to the 8.2 ohm resistors.
Double check all that before blindly following me though.......
Regarding the LEDs, are they in the correct way round?
Managed to sort out the heaters (filaments).
I changed a new 7805 bought from Mouser to an old AN7805 and now it works. LEDs work aswel.
One last problem popped up ... right channel is clearly more "silent", like it has way less gain and no mids. But I hear sound from it.
Any suggestions?
Now it's about wiring.
