How to use DCin instead of ACin?
Got a board from ebay delivering +V and -V with LM317/LM337.
The input power is supposed to accept both ACin (3-27V) and DCin (5-40V). ACin connection is obvious, but I cannot get any clear help from the seller regarding how to use DCin to power the board. Is it possible to simply connect DCin to the ACin slots? Or should the DCin be connected somewhere else?
Here below are some pics, hope you can get an idea from the scans.
Thanks in advance for any help.
Not exactly to say it politely.
1) IF the fuy schematic belongs to this supply :
a) Center tapped AC will work fine ,so
ACin (3-27V)
is WRONG.
ACin (3-27V) from center tap/Ground to ONE of AC in pins will work, sort of , because diode will work as a center tapped half wave doubler. Poor Engineering.
b) MAYBE you can connect AC(3-27V) end to end to rectifier bridge and pray output self centers.
Usable at low currents, I would never feed a power amp from that.
2) you can regulate symmetrical raw DC you got from elsewhere , they should state that clearly on Ad.
Plain
DCin (5-40V)?
Forget it.
Poorly worded or described ad, promising things it can never do.
Thank-you all for your replies and comments.
Thought it would be an easy answer solution, but looks not.
Having a spare 2x18V transfo I will connect the ACin for now, and forget about powering the board with a simple DCin. Or, might try later on since the output current could be limited to 100mA (= not asking much to this circuit).
As usual, Rod explains very well.
Project 43 - Simple DC Adapter Power Supply
However, say an 18V DC laptop supply would only yield around +/- 6V max out so not very usable.
It will give half the DC supply in. ±6VDC for 12VDC wall wart, ±9VDC for 18VDC wall wart etc. I've used a few and works well but I've also used other DC in options to give split supplies.
The board in the first post will work with a AC wall wart such as for example 12-16VAC and connects with 2 wires only. See Rod's ESP Project 05-5C and quote: "if a single AC supply is connected between GND and AC2, the rectifier is a full-wave voltage-doubler type, and with an input of 16VAC will provide about +/-20V DC".
P05-Mini This uses 7xxx regs but the same process for LM3x7 regs.
I've used this instead of mains transformers as it's easier and no playing with mains voltages.
You are forgetting 3V drop for LM317/LM337 regulation.
My comment was using a P43 only with a DC wall wart (P43 has no regs).
I'm unsure where you are placing the LM3xx regs in conjunction with the P43? I didn't think they could be used after the output of the P43 as it has a virtual ground and even an LED is unable to use this ground as mentioned in Rod's article. It wouldn't be before as it's already a split supply. 😕
