Earthed heatsink causes hf oscillation
I've just built a pair of MX50 amps with Sanken (Chinese copies) O/P devices:2SA1295Y, 2SC3264Y
The amps work perfectly until I attach the O/P devices to the heatsink, the amps then develop hf oscillation on top of the applied test signal. If I isolate the heatsink from earth the oscillation stops and the amps work as normal. I don't like having the metal work of the heatsink floating and I'm not confident that the stability will remain even if I do. Anyone have experience of this phenomenon?
CFP output, big transistor case. What if smaller case is used ?
What is the frequency of the oscillation? Does it matter if you are driving a load? If driving a load...is it worse on positive or negative half?
I notice no small caps in parallel with the output bypass caps. Does it get better or worse adding 0.1 uF across them?
The answers to those questions might give us some more hints...
I also notice there is not a damped output inductor...I don't think it's a part of this problem, but should be a part of any amp that you want to be generally stable.
I take it the heatsink is directly connected to the circuit earth ?
If so and you are using the correct version of 2SA1295 then the collector is connected to the heatsink so I also take it you have insulated it from direct contact with the heatsink and there is no leakage ?
If there is zero leakage (resistance wise ) then you might have capacitance between the heatsink and the BJT.
If it is not too big a job isolate the heatsink from the earth using a 10ohm resistor then try again.
These are just tests and I am not implying anything as other conditions could apply like a lower standard of BJT manufacture but just tell me if you have eliminated those checks ?
one quick question:
value of R24?
other trouble-shooting issues:
can you upload corrected schematic?
next interesting question: is this a loop gain issue, or an output stage oscillation issue? What happens to the oscillation if you take R17 down to 470/2=235, say by paralleling R17 with another 470 Ohms?
https://www.diyaudio.com/forums/solid-state/357700-earthed-heatsink-causes-hf-oscilla
OK. The schematic supplied is wrong! Please, see attached, the correct version I found elsewhere. Sorry about that, never trust ebay sellers for accuracy!
I thought I recognised that circuit looks like a standard D.Self power amplifier layout especially the value and placing of the Comp. capacitor he has changed some components in later designs .
HIGHLY unusual that a D.Self design has oscillation you sure the compensation components are okay and don't remember the two diodes connected to the output never seen that in a DS design ??
Well not at least in the pages of EW where he put his ideas to in the 1980,s on and I have seen plenty of his designs .
